Eco Coach?
Mangolorian222
Chuck
SF Bay Area
F150 Tremor; Mach 1 HP
Serious question...where is it? I see the setting asking if I want it visible in Normal mode but I do not see any eco coach view anywhere. I see an orange leaf in eco mode and that's it. Tremor if that matters..maybe it does.
TexAg08
2022 F150 Lariat
It shows up in your speedo. It’s a green window/threshold that moved with your Speedo needle. Keep it in that range and your “eco”.
Mangolorian222
Chuck
SF Bay Area
I’ll have to take a picture of my screen. I def have seen it on others posts but I don’t have that.
Mangolorian222
Chuck
SF Bay Area
Go into your "MyView" and Eco Coach will be a selectable option. It is one of my favorite MyView screens.
Strange..don’t have that as an option. Only eco behavior. Wonder if this is a characteristic of the Tremor since economy doesn’t exist lol.
tbinmd
22 KR F150
Eco coach is only on the powerboost trucks.
Ebrou
Mobile, AL
2021 F150 XLT SCREW 5.0L Sport 4x4
I have a 21' 5.0L XLT and I have ECO coach. As another posted, it is in your "MY View" menu, and you select what appears on your screen.
Orlando150
Orlando, FL
Ford
Powerboost has an EV Coach display as well as Eco Behavior. I think EV Coach replaces Eco Coach on non-hybrids. These are both in the trip/fuel menu and also available in My View.
In the Settings menu (on the instrument cluster, not the center display) there is also an Eco Coach menu that has one option: Visible in Normal which adds a little green bar to the speedometer.
Which level Tremor do you have? The ability to add the Eco Coach to the speedometer in normal mode is only available on the all digital display which is Tremor High.
Mangolorian222
Chuck
SF Bay Area
402A, so the high package with the big instrument cluster display. I’m so baffled by this.
Blueshound
Dave
Connecticut
My 5.0 302A has an eco coach display. I can select it from the Trip/mpg submenu. No need for MyView. I use it every once in awhile to reset my foot to eco behavior. For some reason my foot tends to get heavier as time goes on lol .
‘22Powerboost
Joe
CT
2022 F150 Platinum Powerboost, Antimatter Blue
Teacher
I Enabled the eco coach so you see it on the normal drive screen, and as others have said, it moves with your speedometer. Pretty cool, and looks aesthetically pleasing too.
I also noticed that if I get on it a lil, the speedometer needle starts pulling ahead of the green notch, as one might expect, but I also noticed that the green section starts to fade out in color, as you start to push the truck/apply more power. Which is also a way of showing you that you’re not driving in the optimal economical range. Once you let off the gas a bit, the green section darkens back up to the bright green. I found that pretty interesting…and also a neat little twist.
Mangolorian222
Chuck
SF Bay Area
Yep don’t have that either. Must not exist on tremors but why leave the option in the menu?!
Ford F-150 Eco Coach? 4A4E3E5C-3E2E-4065-B6FA-527784D62D85
Ford F-150 Eco Coach? AEDE8764-9FCE-43F2-82EB-64BB0A6F0DB6
Ford F-150 Eco Coach? 8105499C-EDA7-421F-A616-F32C97C87B41
Ford F-150 Eco Coach? F0913DD6-D8EF-4B4B-9BF0-6ED4D915FE2B
SRHAGEN
S
RICHMOND ky
2016 F150 XL SPRCAB Sport 4x4 V8 3.73 36 gl tank.
DOD USAF test track ARMY RETIRED PMEL/TMDE
Me to 22 4x4 XLT V8 sprcab
