Drive Mode Unavailable After Driving in Cold Precipitation
BRDVPRA
BRDVPRA
Bryce
Tulsa
2021 F150 2021 Explorer ST
Yep
Hey All,
I used my OBDII port connector to pull the DTCs into Forscan. The codes were a bit crazy and not sure they are all intertwined with the issue, but I'm reporting them all below in case some one can make heads or tales of what happened. They are all listed as previously set and some were when it occurred and some were not.
C0604 - Active Air Dam Control Circuit Performance
C0630 - Active Air Dam Stuck
P0A13 - Stater/Generator Control Module
U0415 - Invalid Data Received from ABS System Control Module A
U024C- Lost Communication with Seat Control Module
C06A1 - Wheel Hub Disconnect Motor A Control
B1083 - Recirculation Damper Motor
Talk about a mess of codes! I'm thinkin the U0415 and the C06A1 are probably the culprit. Of course, everything is working just fine now.
Any input/advice is welcome!
BRDVPRA
BRDVPRA
Bryce
Tulsa
Yep
It happened again today in the sleet/freezing rain. I turned off adaptive cruise and the 4x4 engaged like a champ.... Pro Tip!
