Do new UCA’s make a noticeable difference?
GIjoe
Joe
2013 f250
I’ve been looking at adding new UCA’s to compliment my fox 2” level. I have no clearance issues with my coilovers so I know it’s not really needed but will they make a noticeable effect to the ride? I’ve read guys say that’ll it’ll feel more planted with them and I’m curious now if it’ll help this jittery feeling I’m getting from my front end. Any thoughts?
Graygoose2021
Oklahoma
Sales
They'd look cool...not sure you'd see much improvement though.
Buyer2021
central TX
retired!
Are you able to get proper alignment / caster / camber with the OE arms + your lift?
If yes, IMO the only benefit of aftermarket arms would be aesthetic, a lighter wallet, and 'placebo effect' on handling / 'planted feel'.
GIjoe
Joe
2013 f250
Yes when I had the coilovers installed I also had them install a camber bolt kit. Not sure if that was needed or not but it aligned just fine
GIjoe
Joe
2013 f250
Would they come with better ball joints?
That alone is worth the upgrade imo.
Also, if they are shaped to return your stock geometry uca angle, then hell yes!
You spent the money on the good coils, why not go all the way?
I had trouble with a truck that was leveled the cheap way when I bought it. I rpped all that crap out of there and replaced everything with Spicer parts.
I understand having a better ball joint and better geometry but is it enough to notice in driving characteristics?
astro_fusion
IE, CA United States
2022 F-150 supercab, 1990 Bronco II
Upper control arms can have added caster in them to improve handling and tire wear but you'll only notice this while cornering, not really a ride quality thing. They can correct the upper ball joint angle when lifted to prolong the life of that part, but this also wont really improve ride quality. What you can do is loosen the lower control arm bushings with weight on the vehicle, let the bushings relax, then re tighten. This might have already been done with your alignment and cam bolts installed.
Eighthtry
Boyd
Heath, TX
2021 Lariat SuperCab 5.0
I say change them and add a K&N filter housing and you will make another 75 hp.
SALEEN961
Radnor, PA
2021 F150 XLT 302A
Automotive Technician
Unless you want to take advantage of the added caster that some brands offer, or the upgraded UCAs fix an issue like binding or being unable to properly align your truck, you won't really notice a difference. The increased caster is only helpful if you plan to go outside of the factory alignment specs or if you can't get your caster/camber in spec with the factory UCAs.
I had Icon Delta Joint UCAs on my 2014 F150 and they were nice, but the polyurethane bushings do need to be removed, cleaned, and greased every 2-3 years if you want them to stay perfectly quiet. The poly bushings did make working on the front suspension a little easier as I could unbolt the upper ball joint and just push the UCA up and out of the way without loosening the mounting bolts at the frame, but most people aren't going to see any benefit from poly bushings. If I were to buy a set of UCAs for my 2021 F150, I would want to stick with factory style rubber bushings.
GIjoe
Joe
2013 f250
Thanks for the detailed explanation ?
hotrodmex
Ca
22 Lariat 500.5a
So, it doesn't sound like there is any benefit for the CV axle angle when lifting the front end?
The CV angle is tied to wheel position, so nothing affects it other than your ride height relative to the differential., or switching to portals.
amschind
Adam
'21 F150 SCrew 4x4 Powerboost
Physician
I bought a set of forged UCAs with my Fox 2.0 and Tremor control arms. They're adjustable and forged steel isn't gonna break, but other than that no real benefit.
