Do I have a bad door seal?
RyanStroeder
Calgary, Alberta, Canada
2021 F-150 Powerboost - Leadfoot
21 Powerboost here
With the cold weather lately, I’ve really noticed the lower area near the door to be colder than I would guess it should.
Coupled with the fact that I’ve always thought there is more road noise than usual coming through the two driver side door, I can’t help but wonder is my seals aren’t sealing correct.
attached is a couple pictures of the driver side door (both front and back). Can anyone comment on if the frost and mud/slush pattern is consistent with an improper door seal?
thanks in advance
Ford F-150 Do I have a bad door seal? IMG_2372
Ford F-150 Do I have a bad door seal? IMG_2373
Ford F-150 Do I have a bad door seal? IMG_2374
PB2021
Rob
2021 F150 Lariat Powerboost
The seal looks intact but I’ve never seen anything get in past the inner seal on the door itself like that. Combined with your report of wind noise it sounds more like your door may not be aligned properly rather than an actual seal
Issue. Just my thoughts
RyanStroeder
RyanStroeder
Ok thanks man - i'll try to figure out how to determine door alignment. cheers and thanks for the response
PB2021
Rob
If your dealership has a body shop they should be able to check it for you and adjust as needed.
