Disable cornering fog lights on 2023?
AdventureTruckVlog
North Carolina
Has anyone been able to disable the cornering lights from their fog lamps on a 2023? I don't want a single side lighting up every time I turn on the blinker or use the steering wheel.
This will be my first attempt at using forscan and I've also read that the 23s are way different from everything before, so I'm hesitant to use old spreadsheets.
Jesse-Infotainment
Jesse
2024 F150 Lightning
No. It isnt different. THe strategy files have changed over time but the 21 runs the 23 strategy file.
hotrodmex
Ca
22 Lariat 500.5a
Ford F-150 Disable cornering fog lights on 2023? 1693255853144
I turned it off, but I think I'm going to try turning the cornering back on while leaving the turn signal activation on off. With properly aimed fog lamps I can see how low speed cornering lighting comes in handy.
Ziggy73
Keven
2021F150 Powerboost
Radiologic Technologist
I haven't, but I'm curious why you don't like that feature? I reamed mine, crank them as high as it will go which isn't offensive to other drivers, but now they actually work not only when I turn, but when I turn the fog lights on I can actually see them, whereas before they were so low that they were pointless.
AdventureTruckVlog
North Carolina
Because I'm switching to yellow diode dynamics elite, so each side lighting up every time I touch the wheel is kinda ridiculous.
Ryan74
California
2023 XLT Carbonized Gray 4x4
so which code here do I use to turn it off completely?
Ppaw
Thomas
In the hills
2023 F 150 Lariat FX4 5.0
How did you crank them up? I too would like to actually see them when I turn them on, not only when I turn the wheel. It seems to me, they are too dim and doesn't seem to make much of a difference when going straight down the road. I do like them though when turning.
Blue22
Southeast, PA
I think you will find out how to adjust them in this thread. Mine were low too and after adjusting them up, they work much better.
https://www.f150gen14.com/forum/threads/fog-lights-aimed-like-crap.4789/
FORDTEXAS
2022 F150 LARIAT
another option which i personally do is just keep both on at all times lol.
DK4
Truck
I normally do this with all my trucks, but on the 14th Gen having the fog light on kinda drowns out the LED c-bar on the outer edges and bottoms of them.
FORDTEXAS
2022 F150 LARIAT
funny you say that because i feel the opposite. the trucks headlights being on without fog lights looks kinda funky imo. but to each their own at the end of the day lol.
