Yeah I thought about resistors but I’m not sure if they would work the same as on a halogenI have used resistors to dim led licenses plate lights on a 2010 ford explorer. I dont know how the led dimmers work but I dont see a problem as long as you have the right wattage resistors or led dimmer.
In case you where wondering the license plate lights where so bright I could see the road for a good distance behind me at night and it was distracting to me let alone other drivers.
i doubt it.. LED’s draw significantly less power than halogen/incandescent bulbs do.Yeah I thought about resistors but I’m not sure if they would work the same as on a halogen
yes, you can use resistors and they will dim led lights. That is exactly what i did with my licenses plate lights and said that in my first post. you will need a range of resistors ohm readings to find what brightness works for you. i cant give you an exact ohm resistor so trial and error is your best bet. i would also do the testing on a bench not in the vehicle just use a 12v battery as a power source. once you find what you like heat shrink the wires and resistor i used marine heatshrink because it has hot melt glue on the inside for a more waterproof connection. you will probally be fine with 1/4 watt sized resistors.i doubt it.. LED’s draw significantly less power than halogen/incandescent bulbs do.
Use a PWM dimmer.I’m wanting to get a Putco illuminated ford emblem but they are just too bright for me. You think it would be possible to wire a 12v led dimmer inline to reduce the brightness? Or if a resistor would work?
