SilverPigeon
Apologies if someone has already covered this subject.
Ok, so ages ago I did the Rock Crawl Mode addition to my 4x4 KR. Recently, there have been threads with peoples' comments mentioning that they'd like to default to Sport Mode, not Normal. It got me thinking so I went sniffing. The Selectable Drive Mode settings in the ABS module do the enabling/disabling of drive modes. Mode 10 is Rock Crawl from livnitup's fantastic sheet and even notes that point out mode 1 is Normal and mode 2 is Sport. So, I thought, what if I disable mode 1; will it default to the next lowest mode number of 2? See attached video.
Default to Sport Mode Test
In the video, you can see that there is no more Normal mode to select. However, the blue theme of Normal mode stays up. The ABS did the right thing by setting 4A automatically though. Now, when I change drive modes with the knob, you can see that there is no more normal mode and, during that ignition cycle, switching to Sport shows the correct Sport theme. On key on after a key off though, back to the Normal theme. This makes me think that the IPC has a coded default of showing the Normal mode theme (I can't find a setting to modify for this) ?
the "But" is as described above. So if you are prepared to lose Normal mode, the only thing left is for one of you who always uses Sport Mode to actually drive test for all the characteristics of Sport Mode. You need to do this after a key on engine running WITHOUT turning the drive mode knob such that Sport settings are in place but the blue Normal theme still shows on the cluster.
Of course, it would be nice if the Sport theme came up on key on too ?
ABS: 760-04-01 xxx* xxxx xx-- SDM Generic Mode1, 1 = enabled, 0 = disabled.
Oh, if you ever get an ABS software update, you'll most likely have to re-do this change; the servers know you should have Normal Mode ?
