Deertic
I have a 2021 F150 XLT Fx4 supercrew. A very annoying dash rattle began about 3000 miles. Rattled with every bump in the road and constantly on gravel. Sounded like it was coming from behind the drivers side right hand air vent. After MANY frustrating hours searching and holding pressure on parts of the dash and cramming foam rubber in trim junctions to no avail, I found and fixed the problem. Behind the climate control part of the dash I found a metal part that I think is part of the touch screen had a screw loose and it would not tighten down. There was at least 1/8” of play between the part and the frame where it was attached. I slipped a nylon washer between the screw and the mounting plate and tightened it up and the problem is fixed. Just trying to help the next guy with an annoying dash rattle.
