Crush washer "trick"
Rinn69
N Central IOWA
Retired USAF Medic
I bought a bag of 10 copper crush washers on Amazon so when I install an oil drain valve, I won't have to use an aluminum crush washer. After watching a video about annealing them, I decided to check to see if my new ones were pre-annealed....they were not. I tried to bend one with my fingers and I could barely do it. So off I go with my little butane torch and a cup of water, hung 4 on a wire, heated them to red hot, and dropped them in the water. I fished one out and could easily bend it. Mission accomplished.
TLDR: Anneal your copper crush washers before using them.
I don't understand wanting crush washers to be softer. ??‍♂
I'm one of the weirdos that has changed oil many times on several toys and never changed a crush washer with no leaks. Well, I did change them once on a bike since some genius apparently used an impact on drain plugs. Still have pack of crush washers somewhere in toolbox.
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
My drain plug has an o-ring on it, no crush washer ?‍♂
Rinn69
Rinn69
N Central IOWA
Retired USAF Medic
So it can conform to the sealing surface better and use less pressure (torque) when tightening the oil drain plug or valve to achieve a good seal.....without the use of an impact ?
