mdn14
Can you take a picture of what you're referring to/how you're using it?Update:
This tray does not require a safe for it to sit on.
As stated in a previous post, I'm a dufus and ordered the tray not paying attention to what it was designed to work with. I just liked the idea of the tray being the full size of the console opening.
When I received it, I removed the half-tray that came from Ford and went to set this tray in its place. ???
Yea, it just falls right into the console.
I knew that wasn't right, because I'm a genius that way?
So I set the Ford tray back into the console and centered it and then set this tray into the opening.
Perfect shape and matches the opening, but I found that it took a little push on the console lid to latch. Nothing terrible, but the weight of the lid wasn't enough on its own.
It's been a few days now and it appears that the pressure on the tray from the lid, which is from contact in a very small spot on both sides, has altered the tray edge enough that everything works perfectly. It latches now with the smallest of touch.
I'm guessing that if someone wanted to get this perfect fit immediately, a little heat gun directed at the two spots that have the minor conflict would be an easy solution.
