Climate Control not working
Big Smokey
Doug
Calgary, Alberta, Canada
2022 4X4 Platinum 7.2 KW Powerboost
Our 2022 PB climate control is running hot. It continues to blow hot air no matter what the temperature setting is until you dial it LO. At LO it blows really cold air. Anyone else have this issue.
tbinmd
22 KR F150
Could be a bad module, damper/solenoid or sensor. You would need Forscan or other scanner to check to see if there's any DTC's set. Sounds like you need to take it to the dealer.
