Chassis ground for accessories?
TheArborist
Dustin
Alberta, Canada
2022 F-150 Powerboost, 2022 Explorer ST
Hey all, looking to do a 12V accessory panel at the back of the truck for off road lights, air compressor, etc.
Wondering if anyone has gone down this road and if there is an ideal spot to ground to the chassis on these newer F150s?
Thanks in advance!
astrand1
Alex
22 Ford F150 Powerboost 7.2kw
Studio truck driver
Thanks in advance!
On the frame. Not the body. There a few frame grounds in the back but if you need one in a certain place just make sure it’s clear and drill a hole. Clean to bare metal attach your ground and then I’d suggest hitting it with some black paint just to stop or slow down any corrosion.
WD8CXB
South Amherst, Ohio
2023 F-150 4x4 SuperCrew / 2020 Expedition MAX 4x4
Electrical Engineer
For the best operation take a ground/common/negative all the way back to the battery. If this is not desired then I agree with @astrand1 and go to the frame, not the body. I am one that will run a ground wire all the way back to the battery. This is a must for my trailers! I do not use frame ground nor use the hitch as the ground connection to the truck.
