Cable run...
BHunted1
Sumner County TN
Anyone know a way to run a cable from inside cab wall behind rear seats to outside of cab?
So much crammed back there, I have not located an access hole to the outside world. TIA. :)
sbreech
Steve
Central Ohio
'21 F150 STX, Lead Foot Grey
Systems Administrator
Do you need to go to the back of the truck or to the engine compartment? There is an available grommet to go from the engine compartment into the cab of the truck, then it can run along the floor sill panels to behind the rear seat, if that is what you need. I just ran a power wire for my amplifier that way...
BHunted1
BHunted1
Sumner County TN
No. I need to run coax out of cab from under rear seat through wall (where amp is mounted), behind to bulkhead in bed.
Thanks.....
KartRacer25
Richard
San Diego
Someone said water can come in from hole behind sub woofer. So maybe try there.
I just did the forward route through firewall at grommet for light switch.
