Boost issue 2021 ecoboost
keno199
AZ
2021 F150 XLT 4x4
I am trying to determine what might be causing a low boost issue. I scanned with Forscan and no codes.
2021 XLT, 76K miles, no issues until recently.
The boost will only build to half of the boost gauge and the truck is sluggish on acceleration. I usually run 87 and tried 91 to see if it would help, it did not. I used Boostane and ran a mix of 94, it did not. Nothing helped with octane ratings, still half boost.
I cleared the adaptation across all modules, drove the truck moderately to recalculate the tables. Once calculated I floored it, and the boost returned to almost full boost gauge with the return of power.
Drove for a few more days and back to half boost and sluggish performance. Cleared the adaptations and the power returned. No codes are ever presented. I don't know if there is a failing wastegate, but no codes support a mechanical failure.
The truck in 100% stock. There are a couple of changes i made with Forscan but none impacting performance.
powerboatr
North East Texas, Piney Woods
2024 F250 King Ranch Chrome
Retired Navy Senior Chief
Obvious question
Mpg change
Air filter condition
Oil consumption change
JJSnell
JJSnell
CdA, ID
2022 F150 Platinum FX4 PB
I agree with @powerboatr, when was the last time you replaced your air filter? Or confirmed it was? Autoshops are pretty notorious for 'replacing air filters' and they dont. If its a reusable, (Banks, K&N, etc), when was the last time it was thoroughly cleaned? You can boost all day long, but if airflow is blocked, its blocked....
keno199
AZ
2021 F150 XLT 4x4
Obvious question
Mpg change
sorry should have included: new plugs, new air filter, no oil consumption, oil is clean. No odd sounds. MPG is 20 hwy, 15 city.
SALEEN961
Radnor, PA
2021 F150 XLT 302A
Automotive Technician
Can you tell us what the learned OAR (octane adjust ratio) or KOM (knock octane modifier) is when you're experiencing the issue?
keno199
AZ
2021 F150 XLT 4x4
Sure. I am guessing this is stored in the adaption table. Where is it located in Forscan?
SALEEN961
Radnor, PA
2021 F150 XLT 302A
Unfortunately I don't think Forscan is able to display these pids and most scan tools can't either. These pids are extremely helpful when it comes to diagnosing issues like this but they are usually only readable with an SCT, HP Tuners, or similar tuning device.
keno199
AZ
2021 F150 XLT 4x4
thanks. I don’t have those and there is not an error code.
SALEEN961
Radnor, PA
2021 F150 XLT 302A
My guess is that your truck is learning a very high OAR / low KOM due to false knock. This would explain why clearing the adaptions returns your truck to normal boost levels while also explaining why higher octane fuel didn't help and why there are no codes present.
Check for anything in the engine bay or around the exhaust that might be loose, hitting, or making noise.
powerboatr
You also could do a data log run
But requires a driver
Your laptop
And select all the pids for baro pressure,
Cylinder contribution
All the good stuff under ecm
Boost, etc. No more than 20, as it's aton of info
Put it in graph so easier eyeballing
Sit in passenger seat and have someone drive
Henfield
Usa
Take the time to follow all the hoses from the air intake, onwards until they enter the air now boosted, heated and intercooled enters the engine. Look for damage (impact or rodents), loose clamps, loose hoses....
Best done with a cold engine........
keno199
AZ
2021 F150 XLT 4x4
I will. It seems like a loose hose would kick off a code. Why would power restore when the adaptations are cleared.
SilverSpur
Tony
Joplin Mo
2021 F150 XLT, 08 Charger RT, 24 Santa Fe Hybrid
I would return all settings back to stock and see if anything changes. Then add back changes 1 at a time to see if any issues.
keno199
AZ
2021 F150 XLT 4x4
The changes made were Bambi lights, and disable double honk when the key is removed and the trick is running. Changed 3 years ago when I bought the truck.
The boost loss is increasing. Last night I data logged, then cleared adaptations and data logged again. Full boost returned for about 15 miles and started dropping off again. Drove about an hour this morning and now making about 40% boost.
Did Ford push an update that might be janky?
Should I flash the truck back to as built?
SilverSpur
Tony
Joplin Mo
How is the fuel pressure? A clogged fuel filter can cause the low-end power loss.
