FirstFordF150
Hey Jesse-infotainment. If you have time could you check my vin # 1FTFW1ED5NFB53178 for any updates and confirm Blue cruise maps are updated 10/12/2022 (Dec 10). Thank you for all your help.
Hi Jesse, just got my car back from the dealer after a full day of updating things. After a short test drive on the freeway, there's no indication of any change, still no Hands-Free BC so far....No probleem. All you need is a USB drive if I sen d you the files. Check with the deaelr see if they will do the gateway update if they give you a hard time I can send you the files. Takes 15 mins to install
They did do the Gateway update. So give it some time. it seems the amount of time required for the maps to reinsstate has been taking a bit. To give it a few ignition cycles and youll be set to go. Side note looks like the RFa update came after the gateway update. That RFA update will enable the Phone as keyHi Jesse, just got my car back from the dealer after a full day of updating things. After a short test drive on the freeway, there's no indication of any change, still no Hands-Free BC so far....
Will you please look again to see if anything was changed at all, or my software/BC map situation still stands as yesterday preventing me from using the H-F BC. It would be helpful to decide what to do next.
If further changes are needed, going back to the dealer is not an option since it seems no one at the dealership (sales and service both) even knows or understands the existence of a Hands-free BC. They keep talking about the nagging kind and that's it. It is truly puzzling....
Thank you.
1FT6W1EVXNWG11113
That is reassuring! Thanks so much again for checking.They did do the Gateway update. So give it some time. it seems the amount of time required for the maps to reinsstate has been taking a bit. To give it a few ignition cycles and youll be set to go. Side note looks like the RFa update came after the gateway update. That RFA update will enable the Phone as key
Yes you will have to deal with this every three months. They dont keep them active for the entire time in the truck.That is reassuring! Thanks so much again for checking.
In-vehicle Sync4 now states that my Hands-Free Driving Mode available through 10-09-2022. Should that mean September 10 I suppose it will update to a valid date automatically along with the rest of everything after a number of ignition cycles, as you suggested, or by an OTA update perhaps?
Interestingly, in my Connected Services Ford BC shows active until 09/09/2025.
Just like you said...Yes you will have to deal with this every three months. They dont keep them active for the entire time in the truck.
Ford hopefully before december will have this under control for the 22s. The new dat is 10-12-22
The date change seems to be taking some time after the update. Mine happened fast but the 22s have different packages than the 21s and different gateways.
If you have forscan you could force the gateway to reset and possibly expidite the update.
A guy I sent the update to told me today his finally updated the date. He installed the update Wednesday or so. As long as the gateway update was done you are good to go. I saw they did it. So hopefully overight will give the gateway enough time to reset and update the date.
I’m glad to hear and thank you for what you sent! I am glad to be able to help out. Hopefully ford will be better next time with the update roll outJust like you said...
The expiration date has changed to that exact date by this morning after quite a few ignition cycles last night. Hands-free BC is working now as it was supposed to from the get go.
You're contribution to this great community is essential. Thank you!
Yeah if that is the date showing its expired. Lie I have said that is meaning September 10 22Jesse,
Could you check my VIN please?1FTEW1C83MFC38116
Blue cruise handsfree was working fine all year until last month. My maps say they expire 10/09/2022. I’ve tried to update several times but it says there’s no update available. Tried calling Ford as well and they said to let the vehicle sit for 30mins then turn it on and try to update but I had no luck there either. Thanks for your help.
