BCM panel
Fantasy-150
America
23 STX
I'm trying to locate the BCM fuse panel. I take it's not the one under the hood or the passenger's footwell.
Thanks
Fantasy-150
Fantasy-150
America
23 STX
It’s the fuse panel in the footwell. That fuse panel is actually part of the BCM itself.
Thanks I found it.
I was looking for the rear power window fuse. I saw some online diagram that said that fuse was a 30amp in position 38. Mine only goes up to 37. Unless I'm missising something.
The rear driver's side rear window won't go back up. All the other windows function including the passenger rear. I doubt if it's the fues. Guess it's off to the dealer. Friday at 16:00 couldn't happen at a better time.
JEB
US
2021 F150 Lariat PB 502a
Thanks I found it.
38 is there. It’s that big fat fuse right above the #1 and #23 fuses. It’s actually a breaker.
Fantasy-150
Fantasy-150
America
23 STX
Ok thank you. I was going to pull that earlier to see what it was. I pulled it. I'll have to get one tomorrow to see if that works. What is it, a 30amp breaker?
I can't recall seeing any in the fuse box under the hood.
