AuxBeam Switch Panel Mount (Engine Mount Bracket + Interior Overhead Mount)
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
Website
www.4x4TruckLEDs.com
2018 Raptor & 2021 Bronco Outer Banks
Drug Dealer of the LED World
So we've been running a switch panel in our trucks for years, throughout all the various trucks we've had. The issue I always had was that there was NO CLEAN way to mount the switch panel. So we created a really clean mount for under the hood that keeps the switch panel located near the battery AND out of the way of your fuse panel. It also allows you to EASILY add more accessories to the circuit without having to disconnect/move anything.
https://www.4x4truckleds.com/kr-off-road-switch-panel-bracket-for-2015-ford-f-150/
Ford F-150 AuxBeam Switch Panel Mount (Engine Mount Bracket + Interior Overhead Mount) 1715277686731-mv
This bracket is made out of Aluminum here in the USA and powder coated black. It mounts on the passenger side and allows the switch control box to "hover" over everything. You can easily access the fuse panel if you need to AND most important... it's EASY to add more accessories to the panel later.
Ford F-150 AuxBeam Switch Panel Mount (Engine Mount Bracket + Interior Overhead Mount) 1715277729441-tu
The other cool add-on we're offering is the Swarfworks mount for the actual switch panel itself. This replaces your existing sunglass holder (only down side) but gives you a really great location for the switch panel. It ties in nicely.
Ford F-150 AuxBeam Switch Panel Mount (Engine Mount Bracket + Interior Overhead Mount) 1715277796258-
You can grab the bracket and/or entire kit here from us: https://www.4x4truckleds.com/kr-off-road-switch-panel-bracket-for-2015-ford-f-150/
