its on every part I have ever seen from fordIs the “Scrap If Dropped” label something commonly seen on Ford parts of this type?
Hello Jesse,That one in the photo is for a 12” screen. You can tell because the LVDS has the additional 2 pins.
as ofthis date all ml3t apims in 12” have nav also. So you will be good to go with that one
When you get it do the PMI on it and you’ll be good to go
Yes, that is correct. My only concern is when you PMI it you may have get the same issue. I hope not but its posisble.Hello Jesse,
I think I’m going the route of replacing my APIM to try to fix my disoriented screen. Will thisAPIM work with 12”, NAV?![]()
Thank you. I updated to 22905 this past weekend with no change. Any thoughts on what it could be if not the APIM? When I install the new APIM and run the PMI do I select original module installed or not installed?Yes, that is correct. My only concern is when you PMI it you may have get the same issue. I hope not but its posisble.
Also Lariats just released updates all the way up to 22095.. it has 2 apim update.s You may try that first before doing this.
Quick update. I installed the new APIM today and the current software is at 20312 revision 243. I went backwards on revision but the screen orientation is correct for the time being. There is a 2GB APIM update while doing the PMI that hasn’t loaded for me yet; it reads the USB but doesn’t take the update. I let the truck rest for a bit and trying at agin now.Select original NOT installed. I am worried for you about PMIing the APIM and getting the same result.
Thanks. What’s odd is in most cases it recognizes the usb and then shows indexing complete. It’s recognizing the USB but I’m not getting the indexing message on the screen.It may take a while for it to kick off. It’s most likely the 21146 update that take forever
Hello Jesse, I just wanted to provide an update since you’ve been so helpful. @Mattman figured it out. I installed my old APIM and loaded factory as builts. The screen is fixed. Now I lost my glare free headlight changes I made in forscan. My software version is back to 421 but hands free driving is no longer showing under my sync info.It shows at the top. Youll have to leave it in until it kicks off. dont pull it.. it will most likely kick off when you need to run and use the bathroom or something
that’s great . I really though I had asked you about changes at some point. Oh well glad it is fixed and glad you’re all set!Hello Jesse, I just wanted to provide an update since you’ve been so helpful. @Mattman figured it out. I installed my old APIM and loaded factory as builts. The screen is fixed. Now I lost my glare free headlight changes I made in forscan. My software version is back to 421 but hands free driving is no longer showing under my sync info.
@Omar69845What was your fix? I’m just now running to this issue and dont know what to do to fix it.
Sorry, im having the same issue, whenever i connect to carplay i get a black screen and just stays on the black screen, already tried removing my phone, reseting the screen and still nothing@Omar69845
Your going to have to elaborate if you want/need help.
