I have that with my 2025 platinum with extended bedI cant find many options for my 2023 platinum that come with
Power folding
360 camera
Manual extend
Heated
Blind spot
Power adjust
Puddle lights
Drl nice to have
Any ideas on where I can find this? Boost auto dont have anything with 360
I believe you can just order them from fordAmazing, where can I buy those?
Since you have a 2023 Platinum the wiring should be in the door already.All great advice here. Thank you so much for this. I would like to get this upgrade but now kinda trying to figure out how to put the whole thing together once I source the parts from Ford.
I dont know how to wire these and will need some help, support, videos on how to do it.
Should not be difficult I am sure, however the other thing that kinda worries me is the cost of this. I dont think I will be as lucky as @Griffalo here
I totally missed that it was a Platinum. Yeah, it "should" have the harness with the connectors, but we all know how Ford short-changed a lot of these trucks. You can probably pull the door panel off and see if the connector for the power telescope switch is there. If it is, you're good. Just plug the mirrors in and turn things on with FORScan and you should be good to go.Since you have a 2023 Platinum the wiring should be in the door already.
Griffala-I lucked out and found mirrors from another board member that had the cameras in them (my XLT also had 360 cameras) and I bought the harness for the drivers door, added the wires for the passenger door, installed the telescope switch and trim panel, and new window switch with the power fold option on it and made the changes in FORScan to get mine working. I believe the only thing not working is the white light on the side of the mirrors when you unlock/lock the truck, but everything else works - BLIS, 360 camera, heated mirror, puddle lights, turn signal indicators, power fold and telescope. I even have them programmed to fold in when I lock the truck and unlock after the drivers door has been opened and closed. All in, I did it for about $1500. I also replaced the chrome caps with black textured caps ($63 included in the total) but if you want chrome, that's your call. My truck has the BAP and chrome with all that black doesn't look right. One of the best upgrades I did on my truck. I hated the small mirrors they put on the truck from the factory.
You can only get the powerfold/telescope mirrors with chrome caps but you can get the manual fold and manual telescope with black caps. That was why I swapped the caps to black on mine.
