Amber Headlights + RAPTOR GRILLE [Photoshop] - I'm OBSESSED
fxxkintallguy
Los Angeles, CA
Website
www.instagram.com
2021 F-150 XLT FX4 5.0L 302A 5.5 SB
Ok so I've been on the hunt to figure out how to switch my headlights from white to amber since I got my truck in March. Unfortunately, without some extensive disassembly and some industrial grade soldering equipment, specific LEDs, and experience with disassembling/assembling these headlights, I don't think its going to be an easy task unless someone comes out with a kit later on. Or...just raptor swap (which is probably what I'm going to end up doing).
ANYWAY, I wanted to see what it would actually look like. I did a pretty crude photoshop of it...and oh my god.
I need to do this.
Ford F-150 Amber Headlights + RAPTOR GRILLE [Photoshop] - I'm OBSESSED Amber Lights
mschiraldi
Michael
New Jersey
2021 F150 Lariat Sport 2.7 SCREW
Amber just looks like it belongs on off-road vehicles. I’m a fan!
Mrboom_5.0
Matt
02 Lightning, 18 TT 5.0 platinum, 21 rcsb 5.0
Real estate / Automotive customization
Anyone wanting to do amber drls lemme know ??
UGADawg96
JAX, FL
I need to do this.
Following your Instagram. Keep posting!!! :)
Coolrain
Marcus
NJ
2021 Raptor
to Fraptor or not to Fraptor that is the question....... looks great though!1
Photonicc
CA
Wondering if you could use this kit, but keep them set to amber? Anyone familiar with the Oracle kit?
https://www.oraclelights.com/produc...50-colorshift-rgb-w-headlight-drl-upgrade-kit
No, but from my understanding you would have to cut the lenses of the top headlight and re-glue it back on to install the color changing DRL. The foglight for the 2021+ f150 however can be heated up or "baked" so that the lens will pop right off. Certain headlight lens can come off through baking, but some require cutting. This is the reason I chose not to do color changing headlights on my tesla, as it also requires cutting the lenses like the ford headlight lens. If installed by a professional it should not be an issue, but I am no expert. Other than that it looks bad ass for sure, and it has several color options especially if you use the bluetooth controller (amber should be on there)
