gtff150
I own a 2022 F150 XLT, 3.5L EB, 3.55 Elec Lock rear, max trailer option. I am seeing on different forums that I need to change the transfer case, TCCM and shift switch to add TOD. Then there is reprogramming involved using another trucks Vin # that has this option.
When I looked under my truck the transfer case part number tag installed is ML34-7A195-AG. Online I can only find ML3Z-7A195-AG which is TOD,3.5L, Hybrid transfer case. What does the "4" and "Z" represent in the part #'s respectively?
When I put my Vin # in on Ford OEM parts website it comes up with ML3Z-7A195-AJ , electronic transfer case, (Which should supposedly be installed on my truck). This does not have TOD, which would be the correct part number for my truck but that is not the tag part # on my transfer case.
Is it possible that for some reason the factory happened to put the TOD transfer case in my truck because I am being told on another forum that XLT's only get the
electronic transfer case. If that is the case I would only need to replace TCCM and shift switch with reprogramming to follow?
