Adding OEM Engine Block Heater?
Snippy
Mods, I listed this under general topics as I’m unsure if it should go somewhere else.
In order to be prepared for the future cold weather, I’m wanting to add the OEM engine block heater. I’ve never personally installed one. Is it difficult? I see videos for aftermarket ones on older f150s but nothing for the new one. Thanks!
Doyouevenboost
Brian
Minnesota
2002 Subaru, 21 f150 502a ecoboost
Utility maintenance worker
What engine?
Doyouevenboost
Brian
Minnesota
  1. Drain the cooling system.
    Refer to: Engine Cooling System Draining, Vacuum Filling and Bleeding (303-03C Engine Cooling - 3.5L EcoBoost (BM), General Procedures).
  1. Remove the air cleaner outlet pipe.
    Refer to: Air Cleaner Outlet Pipe (303-12C Intake Air Distribution and Filtering - 3.5L EcoBoost (BM), Removal and Installation).
  1. Remove the air cleaner.
    Refer to: Air Cleaner (303-12C Intake Air Distribution and Filtering - 3.5L EcoBoost (BM), Removal and Installation).
  1. Remove the LH air cleaner outlet pipe.
    Refer to: Air Cleaner Outlet Pipe LH (303-12C Intake Air Distribution and Filtering - 3.5L EcoBoost (BM), Removal and Installation).
  1. Disconnect the block heater electrical connector.
Ford F-150 Adding OEM Engine Block Heater? {filename}
Ford F-150 Adding OEM Engine Block Heater? video
Ford F-150 Adding OEM Engine Block Heater? Hel
  1. Remove the block heater.
    Torque: 41 lb.ft (55 Nm)
Doyouevenboost
Brian
Minnesota
i wouldn't be surprised if the heating element was already installed, but i cant verify due to me having one factory installed.
KielerFarms
Kenny
2017 f-150 waiting on 2021
Beef farmer
I had one in my last 150 and never used it. I live in Wisconsin and it gets sub zero here and never had any issues. I figured I'm more likely then not to forget to unplug it.
Billy231
Billy
Long Island, NY
2021 F150 Lariat Powerstroke
I purchased a truck from dealer inventory in Rhode Island with the 3.0 Powerstroke and someone ordered the truck without the engine block heater option ($90) and inquired about getting that cheap option added prior to picking it up. They said sure that can be done, quoted me $650!!
No thanks, I will pass on that one. I will try another route at a later date. Seemed overly expensive.
Kanuck
Winnipeg, Manitoba
Retired Electrician
When I ordered my truck, the block heater was included with any truck needing the front license plate bracket. My cord is sitting behind the bracket. Was an automatic item that was included.
ESG406
Ed
Union City PA
21F150 Hyb, 15ExpEL 2 '06 Esc Hyb 99&01elect Rngrs
Hello Billy,
I bought KATS 11815 (amazon) $38.93. Have not used yet, Talked with their tech support, liked the concept and what they said. Not difficult to install. my 06 escape hybrids get better mpg in winter starting the drive with warm engine. I installed heaters on both
regards,
Ed
