Knickell
Mazda Protege, Ford F-150
Here is a quick look at the LED Projector Headlamps and LED Taillamps on the 2021 Ford F-150.
These particular headlights are the dual beam style and what Ford calls "LED Projector with Dynamic Bending Headlamps". There haven't been any photos or videos showing this style of headlight on an F-150 yet. I also had not seen them turned on and in use until I found this truck at the auto show, so I had a partner work the switch and got this video for you all!
I found it interesting that the amber colored strip in the middle of the headlight housing does not appear to be a turn signal. Rather, the signals/emergency flashers are located at the bottom of the light as you'll see in the video. It took a while for us to figure out the knob that activated the lights because it was not working as it typically would because of the battery maintainer the truck was hooked up to, but you can still get a pretty decent look at how they work!
These LED Projector headlights are included on the F-150 starting with the Lariat 502A High package and higher trim levels. This F-150 was the Limited model.
This is a similar video of the LED taillights in action. The rear LED lights are also standard on Lariat 502A High and above.
I’ve also attached some up close photos of the headlights for you viewing pleasure!
C-shape signature LED lighting, headlights off
Ford F-150 First Look: 2021 F-150 LED Projector Headlamps & LED Tail Lights? 9BF004DD-B4D8-404E-A8CD-7FB444F1B52C
Close up of C-shape signature LED lighting
Ford F-150 First Look: 2021 F-150 LED Projector Headlamps & LED Tail Lights? 01B4F549-3540-4734-8A0A-FB9CEF04ED86
LED Projector Headlights with signature lighting on
Ford F-150 First Look: 2021 F-150 LED Projector Headlamps & LED Tail Lights? 15B8D44A-E92D-4821-B4D8-FA0036324369
LED Projector Headlight Close Up
Ford F-150 First Look: 2021 F-150 LED Projector Headlamps & LED Tail Lights? 701C4F67-83D2-4718-B527-4D69C202567F
LED Projector Light Close Up Part 2
Ford F-150 First Look: 2021 F-150 LED Projector Headlamps & LED Tail Lights? 0967791C-72B1-47A4-909A-76BD466A77E5
LED Taillights Full View, brake pedal depressed. LED CHSML (Center High-Mounted Stop Lamp) and LED Bed Light also activated.
Ford F-150 First Look: 2021 F-150 LED Projector Headlamps & LED Tail Lights? EAAAE07A-6758-46CC-9841-353F42AF11FF
LED Taillights with headlights on showing red C-shape signature. Also see LED bed light.
Ford F-150 First Look: 2021 F-150 LED Projector Headlamps & LED Tail Lights? A3672481-41B1-41A0-A9B9-CEEFE22B1914
LED taillights with brake pedal depressed
Ford F-150 First Look: 2021 F-150 LED Projector Headlamps & LED Tail Lights? 407F1666-0F79-406C-9228-DA5F67F76DD3
Fathardtail
Melinda
Sandpoint ID
2021 F-150 Platinum Powerboost
Entrepreneur
What color is this truck? I like that grey!
dog_tired
Karl
Tampa, FL
F150 Gen14 Platinum Hybrid; Tesla M3
Kyle,
Did you have a chance for your helper to turn the steering wheel to see if the headlamps moved?
Great photos and videos. Thanks for posting these.
Knickell
Knickell
Kyle,
I thought of that, but the steering wheel was in the security lock position, the same way as when the truck is off so I couldn’t move it.
KBKEITH
I work for a top automotive LED supplier and I personally fully disassembled one of the dynamic head lamps a few months ago for some analysis. All I can say is that a replacement unit is going to cost a fortune! Nice lamp, though. It should be very robust from a thermal management point of view.
Ryan
Clay WV
2021 Ford F150, 2004 toyota sequioa, 2010 toyota corolla, 2000 Jeep TJ
Banker
I have had mine for a few days now and driven in the dark a lot. The headlights are fantastic and i don't believe the lights actually move, but it uses the led running lights in the bumper to turn on as you make a turn. it's really nifty. I wish mine had the LED tail lights though.
dog_tired
Karl
Tampa, FL
And this is one of the main reasons Albert with Granger heavily endorsed obtaining an ESP. One headlamp assembly is close to the cost of the ESP.
KBKEITH
You have an XLT 302A? You don’t get the dynamic LED headlamps with that. I believe that’s Lariat and up. Although I do agree that the LED reflector lamps on the XLT are fantastic! Love mine. Major improvement to the older halogen lamps.
KBKEITH
Fortunately LED lighting is extremely reliable with thousands of hours of life. Unless there is a poor design in the driver circuitry and/or thermal design, LEDs should not fail.
pog19
Pierre-Olivier
montreal
f150 xlt 2017
J'ai également joint quelques photos de près des phares pour votre plus grand plaisir!
Éclairage LED signature en forme de C, phares éteints
Gros plan de l'éclairage LED signature en forme de C
Phares de projecteur à LED avec éclairage distinctif allumé
Projecteur LED Phare Close Up
Projecteur LED Gros Plan Partie 2
Feux arrière à LED Full View, pédale de frein enfoncée. LED CHSML (feu d'arrêt central surélevé) et éclairage de lit LED également activés.
Feux arrière à DEL avec phares affichant la signature en forme de C rouge. Voir également la lumière de lit LED.
Feux arrière à DEL avec pédale de frein enfoncée
[/CITATION]
Apparemment, les lumières sont directionnelles
