BenD302
Ben
Delaware
24' F150 RCSB, 17 Infiniti Q60 700awhp retired daily
Truck Driver
I was a little bummed out that the OEM Ambient lighting wouldnt work on my 24 but I wasnt going to be defeated, I did the console swap on Saturday and finished up the wiring earlier, this is a combination of OEM parts with an aftermarket Fiber Optic lighting module and it came out perfect, if anyone else is interested in this I can provide the parts needed and assist with whatever questions to do the install.
OEM Bin Light
OEM Lighted Cupholder rigged with Fiber optics
Fiber Optic behind the seats and under the dash
About $200 in parts
Ford F-150 2024 F-150 RCSB - Hybrid Ambient Lighting Install 20250126_185349
Ford F-150 2024 F-150 RCSB - Hybrid Ambient Lighting Install 20250126_184953
Ford F-150 2024 F-150 RCSB - Hybrid Ambient Lighting Install 20250126_184822
OleMustyBag
Spring, TX
2023 F150 XLT 5.0, 2015 GMC Acadia, 1963 ChevyNova
It looks awesome! Great job!
I am interested in the parts! I am working on a custom trim panel for an expedition rotary shifter to replace the Stick shifter in the center console and I was thinking about lighting it with fiber. I bought some PMMA filament and was going to light it with a OEM LED tapped off the ambient lights. How did you light the cupholder with the fiber?
JCsTruck
Worcester MA
Excellent work and subbed.
BenD302
BenD302
Ben
Delaware
Truck Driver
This is the module I used https://vaistech.com/ambient-lighti...FEme-yVaBrEMHbjHqF7qhJ9wXsWkOvnnqqCDAQXcSnesb
As far as lighting the cupholers, that was a stroke of luck, I simply removed the LED's from the little OEM housings and drilled the back to accept the Fiber lights and it worked perfectly
Ford F-150 2024 F-150 RCSB - Hybrid Ambient Lighting Install 20250124_170300
OleMustyBag
Spring, TX
Krazykorean
Ji
AZ
2024 F150
The more I see console swaps while keeping the column shifter, makes me just want to keep the column shifter. Its not too bad and Im finally used to using that thing. Plus you have much more room in the center console. Nice work on the lighting. I am wanting to do something like this soon.
RedDragon65
Eastern PA
2022 F150 Lariat Powerboost FX4
Engineer - Retired
OEM Bin Light
About $200 in parts
Really appreciate you sharing! Where did you pickup the Ambient Light sense/trigger from on your install? - was checking the interior fuse box for a tap - but don’t see anything obvious
Stefanolimotta
stefano
21 f150
Construction
OEM Bin Light
About $200 in parts
Did you do Forscan changes so you can change the colours from the infotainment screen or did they loose the option for changing colours when they went to the 14th gen?
Stefanolimotta
stefano
21 f150
Construction
OEM Bin Light
About $200 in parts
Jmwillets
Joshua
Central Florida
2025 F-150 STX FX-4
Safety Manager
Have you or has anyone considered running two of these modules and send illumination to the door panels to reclaim ambient lighting? On my 2025 the four LED slits and four holes are still present in the door panels, however they lack the LEDs, harness, and BCM lacks logic too support ambient lighting.....
