Rear parking light wire - for ambient lighting
FastHamFreddy
Fred
Alabama
2021 Ford F150 XLT
Project Manager
Does anyone know if the rear parking light wire runs under the running board under the passenger door?
man’s if so, which wire would it be?
wanting to install ambient lighting that acts more OEM, lights up when it gets dark out, and figured that would be a good wire to splice into.
thanks!
FastHamFreddy
FastHamFreddy
Fred
Alabama
2021 Ford F150 XLT
Project Manager
Been trying to do some research on this, as I am wanting the ambient lighting to be on when I get into the truck at night, and not during the day.
The rear parking lights don't seem to come on until they sense low light levels. So I am wanting to tap into that.
Please correct me if I am wrong about this, but this will allow the lights to be on when I approach the truck, open the door, and stay on while I am driving.
According to the link below, it appears the violet/green wire would be the left rear, and the white/orange would be the right rear.
I am wanting to splice into these wires and not set it up the way they have it intended, because the way they have it set up to plug into the delayed accessory feed (fuse 2 under the passenger dash) would only light up once the car is started.
Would anyone be able to confirm that splicing into either one of these wires would work for ambient lights and have them function as stated above?
I am looking at two different kits sold on f150leds.com or opt-7.com. These would also require me to cut the fuse option off, and splice it into one of the wires stated above.
2021 F150 Wiring
https://www.the12volt.com/installbay/forum_posts.asp?tid=146917
f150 Leds
https://www.f150leds.com/collections/2021-f150/products/2021-ambient-led-lighting-kit
opt-7 Leds
https://www.opt-7.com/aura-led-inte...9k4pNSA5YGtclFHqH6PeCAQSntmZMGPYaAqZXEALw_wcB
https://support.opt-7.com/743288-AURA-PRO-Single-Row-Interior-Installation-Guide---6pc
eappold55
Evan
2021 f150
Electrician
I'm not 100% sure what wire you need for your application but I found these guys when I was looking for a way to hook a small back up light bar on my 21 f150 xlt and not wanting to splice into my wiring harness. But after talking to them on the phone it sounds like they can make you a harness like this for whatever wire you need to pull power off.
https://specialtyperformanceparts.c...y-vehicles-see-details?variant=41304203296934
FastHamFreddy
FastHamFreddy
Fred
Alabama
2021 Ford F150 XLT
Project Manager
