295 or 285 - need your input
THEREED
New England
I ended up getting BFG KO3 tires in 275 65 20. Not close to rubbing at all, look great as about 1" taller. They definitely look narrower than the Falken AT3W I had before even though they are the same width but I like the taller look. I will end up installing Bilstein leveling shocks in front soon. Probably will go with 1.5" height since I tow.
Parthery
Brian
Atlanta
2023 F150 Lariat 3.5
My Discount Tire said 275/65/20 was the way to go and won't rub. I verified with a local 4 wheel / suspension shop and he said the same. Trying to get the G3s in that size in an SL but they are apparently in short supply.
martin aguirre
martin
arizona
2022 Ford F150 Lariat
Facilties manager
thanks for the update. I may just need to go to another Discount Tire. I think the 275/56/20 would look great and fill in the wheel well space better on my stock wheels and stock suspension. I am also looking at SL tires as I dont need the heavy 8 or 10 ply tires for any type of heavy loading or pulling.
wz00r2
TN
2022 F150
295/65R20 is the correct answer.
Blue22
Southeast, PA
I have Nitto's Recon Grapplers in 275/65R20 SL and they have impressed me over the last 5k miles I have had them on my truck. Granted I haven't done any serious off-roading so take that into consideration.
Parthery
Brian
Atlanta
They have a set of 275/60/20 G3s waiting for me but I really would like to bump up to the 275/65/20s. May have to pick a different tire thats available.
F150Fordzilla
Ron
iowa
2013 Ford Flex, 2018 F150 platinum
manager
So 275/65/20 will fit with no rubbing on the 14 gen trucks. I am running that size on my 2018 platinum 157” but had to add 2” level to prevent rubbing. Got a 25 on order so searching around to see what works with stock height king ranch 157”
