2024 XLT B&O rear port on non-b&o system
Kenotic615
Ken
Nashvill
2024 F-150
I am looking to add a sub to my 2024 F-150 XLT. I just wanted to confirm that the port that the B&O system uses is still in place, but disabled, on a none B&O system. If this is the case does anyone know of a wiring harness for it?
Je1279
Jared
Upstate NY
The A2B port is only on the B&O ACM's. Also, I would strongly consider aftermarket options rather than adding the B&O components.
Kenotic615
Kenotic615
Ken
Nashvill
2024 F-150
Thanks for that.
My thought was to have an easy to use access to speak-level outputs and power.
Je1279
Jared
Upstate NY
Many are extremely underwhelmed with the sub in that system. If you are just looking to add some low end without shaking the mirrors, a Kicker HS10 may be a good option. You will need a t-harness and to run the speaker wires, power and ground to the unit though.
Je1279
Jared
Upstate NY
I know these work for the '23's, you will just need to confirm they work for the 24's also.
T-harness
Je1279
Jared
Upstate NY
Here is a video that may be helpful. Depending on the amp you choose, I would skip the line output converter and go speaker level straight to the amp.
