2024 CHMSL Cam (aka 'Bed Cam')?
Stefanolimotta
stefano
21 f150
Construction
Hi just joined the forum after picking up my new 2024 King Ranch which does not come with the CHMSL camera - it was not even an option on the camera menu. I removed my non-camera 3rd brake light and pulled the harness and saw there were a number of excess wires than the 3 used on the standard light. So I ordered the following part from a Ford dealer parts online - it came with the camera included.
Part Number​
Part Name​
Price​
Quantity​
Total​
NL3Z-13A613-A​
High Mount Lamp​
I then just installed it and ran the FORScan changes the others have suggested and it worked! So if you have the additional wires in the harness under the existing light, it is likely that it will work!
Was you brake light plugged directly into that grey connector? And did you have to fetch that connector behind the head liner because I can’t do that on my truck but I’ve been told it could be behind the bed liner this is what my truck has 25 Lariat 501
Ford F-150 2024 CHMSL Cam (aka 'Bed Cam')? IMG_1195
Tlusk7
Tyler
Kentucky
2023 F150 Lariat
Yes you have to get to that connector, that’s how you tell if you have a pre wired connector. And yes it is above the headliner. I have a video on YouTube showing a bit about it. Around the 16 min mark.
Stefanolimotta
stefano
21 f150
Construction
Oh that’s amazing I’ll try and find that video thank you.
2024lariatbap
Dfw
2024 f150 lariat
So i just got a third brake light camera from Facebook marketplace and I want to work on installing it. I just have the 3 wires at the back of my current brake light. I do have the plug for the camera but the wire was cut so I figure i can just take the cut wire and replace it and run new wire. I saw the terminals i need to buy and where to put them on the connectors. What im trying to figure out is how much length of wire I need to run from the camera to the front and where exactly the wires need to be ran? Anyone who has done this before you're insight would be greatly appreciated.
Tlusk7
Tyler
Kentucky
2023 F150 Lariat
All of the info is on my google drive and YouTube video in my signature below
Stefanolimotta
stefano
21 f150
Construction
Haha I know the feeling, would need to get the bottom of this! That’s interesting! I wonder if it’s just a regular wire to the IPMA to add it for you?
This wire from the junction box to the Iona how long did it need to be roughly? Did you do it yet?
