bmwfrk
Awesome. Glad it worked it worked out. I'm sure people will need to make changes depending on their use cases. I still need to install my sway bar and will probably need to adjust things back a touch. If you're carrying much weight in that trailer you may want to consider the RAS setup like SnakebittenI put my payload settings back to stock values and applied @bmwfrk 's settings in the as-built data this morning. Was easy to do now that my FORscan learning curve is about there.
I drove the truck around quite a bit after the changes. Bump roads, dips in the road, grade changes pulling in and out of parking lots etc. Simply put, it's awesome! The truck feels very planted and sure-footed so to speak. Noticeable improvement over the simple method as the suspension feels so balanced now, and SO MUCH better than stock.
For the last two years since I picked up the truck, I regretted checking the CCD box on the order form. Now I'm glad I have it! I should not have waited so long to dive into FORscan to adjust the settings.
I'm anxious to tow my enclosed car trailer this summer. I may even stiffen things up even more when towing, we'll have to see how compliant everything feels.
Thanks to all who contributed, offered advice, and shared their settings & testing!
