firecat72
So 3 weeks after my truck is out of warranty my washer stops working. When pressing the button on the end of the turn signal stick the wiper work and from reading I have done the wiper and washer are on the same fuse. Order an oem washer from ford and installed it. It also did not work. Bench test the both pumps, both worked. Checked connector and wiring as far as i could see and feel thru the wheel well all appeared to be intact without corrosion. And yes I made sure there was water in the reservoir.
I noted that my truck has an incomplete over the air up date and am wondering if this may have something to do with the washer not working?
Any suggestion on what could be the problem? I hate to have to take into the shop for such a small problem. Thank in advance for any help.
