Bilstein 5100s are now back in stock and shipping for the 21-23 F150!
(if anyone has an order they are waiting on, it should be shipping out asap if it hasn't already, but feel free to pm me)
2021-2023 F150 4WD Bilstein 5100 Adjustable Leveling Shock Kit 21F1504WD
2021-2023 F150 Bilstein 5100 Package Features:
Leveling your truck and getting a smooth factory ride don't always go hand-in-hand. Many aftermarket leveling kits reuse your stock suspension hardware which leaves you with a factory ride and suspension performance at best, if not worse. Bilstein, one of the biggest names in performance suspensions, cuts out the middle man with this 5100 shock kit that includes high-quality adjustable front shocks. These shocks allow you to set your 2021-2022 F150's front ride height to stock, +.50", +1.00", +1.50", +2.00", or +2.50" of leveling by using their adjustable spring seat tabs. The adjustable design is paired up with legendary Bilstein quality and performance that let you take these dampers anywhere for any application you have in mind without fear. Rear monotube shocks are also included to provide extra stability and handling performance for your F150's rear end.
Steel-Cased Monotube Shocks with Unique Piston
Each of these shock absorbers feature an ultra-strong steel body with a zinc plated finish that protects against corrosion. The shocks all feature a monotube gas-charged interior design with a digressive piston and self-adjusting deflective valving which allows each shock to work at varying ride heights and give your truck improved articulation in off-road application. All four shocks feature a large 46mm diameter that gives them a huge oil volume for less fade during heavy and sustained articulation off-road. This complete kit is a direct bolt-on replacement for your factory shocks and can be used with your factory front coil springs and rear leaf springs.
Fitment: 2021-2023 F150 4WD
For 4WD F150's Only: this kit will only fit trucks with 4WD. A version for RWD/2WD F150s will be available in the near future.
Will not fit F150s with CCD: these coilovers will not fit or function on F150s with Ford's optional Continuous Control Damping (CCD) system. Please verify whether or not your F150 is equipped with CCD before ordering.
- Complete set of four F150 Bilstein 5100s
- Includes struts capable of 2.50" of front F150 leveling
- Rear shocks provide enhanced rear-end stability
- Gas-charged monotube internal design
- Reuse factory hardware
- Steel bodies with zinc-plated finish
- Instructions included
- Will not fit F150s with CCD System
