2021 2.0 vs 2.5 level
Pizz80
Houston TX
2021 F150 2021 Expedition
I have a 2021 that I put a 2.0 level on. I put on 20x9 rims +1 offset with 275/65/20 that rub like crazy. Would going up to a 2.5 help or do I need to change tire size?
Gman73
C
Ontario
2018 Ford F-150, 2019 Ford Ranger, 2021 Ford F-150 on order
Facilities Manager
I have 285/65/20's on mine with no level at the moment (2" level being installed Friday) and I have no rub issues so it is most likely your offset is the problem.
jeff82z28
Ontario Canada
f150 Fx4
Ford Motor Co
What rims / or offset are you using Gman73?
Rich1982
Rich
Kansas
2021 F150 XLT/302A
Semi retired
Need to increase the offset - the increased lift my help but "rubs like crazy" may not be resolved with just .5" increase?
The factory offset is 44mm - by going with +1mm you moved the outside of the tire nearly 1.7" out - when the tire/wheel turns this means the tire is 1.7" further forward and further rearward - offset makes bigger difference than the tire width (in this case you didn't change the tire width)
ryanblake
Ryan
Lenexa, KS
2021 Ford F-150 XLT FX4
I have 20x9’s +20 offset with 285/65R20 Nitto RG with zero rubbing and zero trimming
Pizz80
Houston TX
If I go down to 275/60/20 would it fix it?
Gman73
C
Ontario
Facilities Manager
I am using the stock rims that came with the truck.
Had my 2” level installed today and upgraded shocks and springs
Ford F-150 2021 2.0 vs 2.5 level AAF2B5D5-1CB8-44EA-85B8-E944F4A9AE8A
powerboost_21
BC
2021 PB XLT 302A & 2021- PB Lariat 502A
295/60R20 Toyo AT3's on stock +44mm offset rims... zero rubbing or trimming. Your rim offset is the issue with your current rubbing.
Ford F-150 2021 2.0 vs 2.5 level PBTruck4
wilmaj32
08 GT500, 21 Powerboost Lariat , 12 Expedition
Your truck looks great! Any pics of the tire poke front and rear with that stock wheel setup.
powerboost_21
BC
Thanks for the props on my truck! Here are a few pics of the tire setup just wanting to poke outside the wheel wells.
Ford F-150 2021 2.0 vs 2.5 level BC9C6B5F-777B-4098-8C4D-AE078E38A16F
Ford F-150 2021 2.0 vs 2.5 level C2A2BE68-2678-4E04-9ACD-E14950023698
Ford F-150 2021 2.0 vs 2.5 level BE8CDF6E-89B6-4B5A-8CC8-5861EFC02D5D
Ford F-150 2021 2.0 vs 2.5 level 33EACDE9-266C-421A-A760-9871A4B391F4
satchamo
Indiana
2021 STX
Perfect - not sure why people want their tires to poke outside of the fender wells unless they either A) never use their truck anywhere but on pavement or B) want to destroy their paint slinging rocks and other junk along the side. Some of these major offsets would destroy your rocker panels in a mile of gravel road driving with as many rocks as aggressive ATs and MTs tend to hold and sling.
