TN_Ryan
- Joined
- Jun 5, 2024
- Threads
- 14
- Messages
- 123
- Reaction score
- 209
- Location
- Chattanooga, TN
- Vehicles
- 2021 F150 XLT RCSB Oxford White
2015-2025 RideTech rear lowering kit for sale, had it on my truck for around 2000 miles without issue. Decided to go 4-Link...so no longer need the rear lowering kit. Comes with everything you need to lower your truck 3.5"-5.5" including the adjustable Fox shocks and the necessary shims for the leaf pack and the adjustable pinion shims. Price is $500 plus shipping.
Below is some information from RideTech's website...
Lower your current-gen Ford F150 up to 5.5 inches in the rear with Ridetech lowering suspension system. More than a lowering kit, system will turn your vehicle into a high-performance muscle truck with better stance, handling and ride quality.
The Ridetech lowering kit is 100% bolt-on, fully adjustable and made in the USA. It includes everything you need to lower your Ford F150 platform.
Lowered stance
– Adjustable ride height – 3.5 – 5.5” rear drop
– Improved ride quality & sharper handling
Adjustable Ridetech / Fox Shocks
– Aluminum Body
– Mono tube / gas pressure
– Adjustable valving
– 1,000,001 mile warranty
Bolt-on installation
– No welding
Optional Traction bars eliminate nearly all wheel hop while still allowing for full load capacity and smooth compliant ride
Optional rear sway bar dramatically increases cornering capabilities
Optional rear air assist / load leveling air springs and mounts
Fitment Notes:
Lowered stance
– Aluminum Body
– No welding
Fitment Notes:
- Does not fit PowerBoost Hybrid trucks (driveshaft clearance).
- Trucks equipped with headlight sensors require bracket kit Part # 12299501
- Trucks equipped with four headlight sensors (On-board Scale option) require bracket kit Part # 12299502
