Rineland
I just installed the EcoFlow Alternator Charger on my non Pro Power truck and paired it with the Delta 2 Max (D2M). It can charge up the D2M at a rate of 800W, not quite enough to keep up with heavy loads, but an impressive charge rate nonetheless. I like that the D2M is portable and can be pulled out of the truck to use it in places the truck can’t get to. Another nice feature is that the alternator charger can push back to the battery from the 2kWh battery in the D2M at either a rapid charge rate or as a maintainer. Great for not missing an OTA. I’ve linked the video to my install of the charger below. I think the system as a whole is a decent alternative if you feel you missed out on Pro Power. For higher output and more battery capacity, you could also choose the Delta Pro for 3.6kW of output and 3.6kWh of storage. Two Delta Pros can even be paired together for 240V split phase and 7.2kW of output!
