120 volts, 20 amps = 400 watts?
fwunder
fred
NJ
2023 F150 XLT 302A Sport 7.2Kw
What am I missing? I was just cleaning up cabin with home vacuum and cabin outlets kept tripping. Ran extension from bed with propower no problem. I don't understand how cabin outlet is stamped 20 amps but only supplies 400 watts. Thanks!
tony72cutlass's'
Tony
Halifax
The receptacle is rated at the 20A but the inverter maximum output current is 3.5A which gives approx 400W.
Diligenthunter
Taylor
Delaware
2022 F150
You’ll need to enable generator mode I believe.
Mash150
Dale
North of the 49th
21 King Ranch, 157, SQ , PB
If the truck isn’t in generator mode, that’s all you will get. If I remember, the screen indicates to turn on generator if the load exceeds the 400 watts.
fwunder
fwunder
fred
NJ
Even in generator mode it still only delivers 400 watts. Assuming since it tripped with vacuum cleaner with generator mode on.
Diligenthunter
Taylor
Delaware
2022 F150
I’ve pulled well over 400 watts from it, vacuum cleaners will often trip arc fault breakers.
fwunder
fwunder
fred
NJ
Thanks. I'll have to put my KillaWatt on it and test just out of curiosity. As I said, when I ran extension from bed outlet, there was no problem.
Mash150
Dale
North of the 49th
FWIW , I assume your truck screen looks similar to this in generator mode. Only 2.4 inverter on my truck though.
Ford F-150 120 volts,  20 amps = 400 watts? IMG_3013
fwunder
fwunder
fred
NJ
Nice! I will try agaIn tomorrow! Thanks!
Yves
Yves
Gatineau, Quebec, Canada
F-150 2021 Powerboost XLT 302A 360 Camera 7.2KW
This is good information. I thought it was always 20A, good to know that I have to put it in generator mode.
Mash150
Dale
North of the 49th
You only require generator mode if plug In more than 400 watts or so. Simple phone charges etc. will run off the truck battery . Plug in a coffee pot , generator mode is called for. The truck will let you know if the generator is required.
fwunder
fwunder
fred
NJ
I stand corrected! In generator mode you absolutely can pull more than 400 watts from both cabin outlets. Heat gun test.
