12" Instrument cluster blank
beau_nugget
Wyatt
VA
2021 F-150
I'm having an issue where the 12" instrument cluster is only displaying the gear selection. (rest of the screen is blank) About every 2-3 mins the cluster will restart and make the Ford chimes (sometimes from the IPC sometimes from the speakers)
I have an active DTC in the gateway module: U2403:92-48 Ethernet Failure With Instrument Panel Cluster Control Module (IPC). Only thing I can think of is changing some lines in forscan that disables the pedestrian sounder
Has anyone had this issue? Battery tested OK. (Truck is the powerboost if that makes a difference)
Dealer is booked out until late august figured I would try a few things before it sits there for a month or two.
Any help would be greatly appreciated! Thanks
