“Best” leveling kit?
Tyler17
Tyler
Oklahoma
2021 Lariat
Do the Ford Performance Fox’s need to be adjusted down too or just the Roush and regular Fox ones? I had the Fox package on my 14 and my fiance has a puck style level on her 13 and the ride was no comparison so I definitely want to go the Fox route again. Im just not sure which Fox set to go with, or to just wait a few months and see if they come out with a new set specifically for the 21s.
ESwart
Eric
York SC
2021 F150 XLT Sport
Tech
Is the a consensus “best” quality kit for level on the 21’s? I’ve seen references to rough country, icon, mammoth, motofab, etc.
Does it matter which one? Any better than others?
I added a 2" front leveling kit and a 1" rear block kit from Autospringkits.Com spoke to Kevin to custom size the front and rear sizes I wanted. Just wanted to give my 2021 2wd a little more of 4wd look / a ltitle more aggressive stance. Also added the F150 decal and blacked out Ford badges to break up some of the red...
I have 20" factory rims and tires, XLT Black sports pkg.
Ford F-150 “Best” leveling kit? 20210807_171424_resized
Ford F-150 “Best” leveling kit? 20210807_171229_resized
Ford F-150 “Best” leveling kit? 20210807_171441_resized
Ford F-150 “Best” leveling kit? 20210807_171447_resized
Ford F-150 “Best” leveling kit? 20210807_171551_resized
JoeMo
St. Louis, MO
2021 f150 Powerboost lariat sport
Went with the Rousch kit. I LOVE IT! The ride quality actually improved over stock. Paired it with a set of 295/60/R20 Ridge Grapplers.
Do you have the max tow package by chance? I’m wondering what my fox shocks will look like on my truck with max tow
pavementends
Idaho
Enginerd
Ford F-150 “Best” leveling kit? 12-28-2021 1-59-05 PM
Der9765
Derek
Pennsylvania
2021 F150 Lariat
Does anyone have any experience with these? Was going to go Fox but hearing they may fail prematurely as they are not specific to the 2021 has me looking around. Really don’t want to wait until April, or later, to get the new Fox kit.
Ford F-150 “Best” leveling kit? 74995681-959C-438D-BDBD-995BB4AC7B43
70Mach1
Dave
Hudson
2022 F150 on order
Talk about late to the game. I wonder what’s different about this kit that needed a 1.5 half after the production of the vehicle to develop when they specifically state that the current version fits with a height adjustment.
Graygoose2021
Oklahoma
Sales
hasnt Real Deal at Akins done a ton of these on 2021's? The Fox?
pavementends
Idaho
Enginerd
Then they used 2015-2020 products, which WILL FIT our trucks, but not designed for them. Apparently, the front strut mounting points are different on the 2021+ so there is some additional stanchion wear anticipated if using the 2015-2020 stuff. Valving and stroke/stanchions will probably be proprietary for 2021+s. Rear mounting points and suspension travel sound identical, so using 2015-2020 rears seems to be fine.
Talked to Stage 3 today about the Bilstein availability. They think late February. So, I'm leaving my truck as is for now. I haven't decided between the Bilstein 5100s using the OEM spring vs full coil over Fox or Bilstein 6112s. Frank at Stage 3 said 5100s using the OEM spring are really quite good, especially if on a budget. As discussed on separate threads, I'm leaning towards 5100s at the 2nd to highest setting to reduce preload a little and maintain a little rake for trailering.
pavementends
Idaho
Enginerd
I don't know anything about them, but it would be interesting to talk to them about why they consider the Gen13 (front) products to be compatible with Gen14s but Bilstein and Fox don't. Roush (with Fox hardware) did the same thing... https://www.roushperformance.com/2015-2016-f150-fox-suspension.html
In the Northwest we have a tire chain called Les Schwab that lifetime warranties everything they install, no questions asked. So obviously I want Les Schwab to install them, despite the fact I could do it myself. Problem is, they won't install anything that doesn't say 2021 on it for a 2021 truck. So there goes the Bilstein and Fox options until their official release...
Rockman5159
Rocky
Marion SC
2021 ford f150 FX4
I have already purchased the Motofab 1.5 spacers... don't have a truck to put them in for another month. I am really curious if anyone has tried them yet? Really looking to keep a slight rake, but also limit the crazy factory stink-bug rake.
I had a 2020 FX4 that I put the Motofab 1.5" spacers on. To me this was just enough to finish the statnce. I have a 2021 FX4 RCSB and I also have the 1.5 spacers to put on it. I also have a pair of coilovers by Rough Country that is supposed to be 2". I havent installed either one because I cant decide which way to go. It rides so good like it is.
Micale
Micale
WA
Installed the falcon sport / tow haul kit today haven’t put too many miles on it yet but my 30 minute drive home was absolutely phenomenal! Much better ride over stock running the toyo open country AT3 in a 35x12.5 on a 18x9.5 +20 offset zero rubbing and no crash bar modification or trimming. I’ll get better pictures later...
Those Volks wheels ?
