“active air dam system fault" question
quitced
Bob
Mississippi
2022 Ford F150 Lariat
Education
I have a 2022 F150 Lariat and have been getting the message “active air dam system fault; see owners manual”. From the this site, I believe I probably need to replace the actuator. Is there any way to determine which actuator is bad or do I just have to replace both?
LFRoss
Ross
Louisville Ky
2021 XLT CREW CAB 5.0
Forklift mechanic
I’ve not had this issue but you can have a friend drive in front of you and once you are above the speed at which it drops they can tell you if one or both sides do not drop. I’m unsure if you can actuate it with a scan tool or Forscan
Jackal
Pioneer, TN
2021 F150 Lariat
Since my last OTA software update, I have gotten this message twice sporadically. My ait dam appears to be working though.
2021 F150 Lariat
markh
mark
Egg Harbor N.J.
2021 Ford F150 Lariat Supercrew 3.5l Ecoboost
My 2021 Lariet was fine until i did an fdrs update 3 weeks ago. Now i've had the same fault 3 times as soon as i start the truck and today when i shut it off. I've got to think it had something to do with the update.
flasch192
Jeremy
Fond Du Lac, WI
2025 F150 1993 Mustang Cobra
Engine Assembly Tech
get it all the time annoying as f*^K !
EdJ
Ed
Tennessee
2023, F-150 XLT
Could be software check out this TSB...
