Will TPMS from 2015+ Raptor work on a 2022 F150?
Greg's 157
CT
22 f150
Does anyone know if the tpms sensors from a 2015+ raptor will work on a 2022 f150? I have a set of raptor take offs from a 2017ish that I was going to use on the truck and just swap the wheels from the gen3 raptor. Hoping the older sensors will work or just get new ones??
SpaceWhiteF150
Montgomery, Texas
I’m not real sure, I would say most likely yes. When I ordered my wheels and tires through custom offsets they came with aftermarket units that linked up perfectly, so I’m pretty sure they will work. I have not done so, I do not know 100% yes or no.
RcFlyer330
Cameron
2022 F150 Limited Powerboost
Yes the sensors should work. Ford from 2010 (probally earlier models too. my oldest ford is a 2010 so i can only confirm to 2010 MY) has used tpms sensors that use 315mhz frequency for the tpms. Basicly any tpms sensor that uses 315mhz should work. you may need to have the transmitter code reprogrammed to your new truck although some of the newer cars can auto detect the sensors without programing. The easyest way to test this is to put them on your truck and drive around for a while and see if the tpms light comes on.
