Will they rub?
1Roger
Roger
So Cal
2023 F-150 Platinum Fx4
I'm wondering if anyone has experience with the following wheels and if they would fit without rubbing. I have a 23 F-150 Platinum with the tow package and want to install a set of 20" x 10" wheels with an offset of 18. Hopefully, I have all the necessary info in there.
EcoB259
GB
22 XLT S Crew
What size tires are you planning to install on the new rims? Any lift or leveling ?
1Roger
1Roger
Roger
So Cal
Stock height, no lifting or leveling, city truck.
12Lariat21
Jonathan
2021 Lariat 502A
Engineering Manager
EcoB259
GB
22 XLT S Crew
I am going to assume you are switching your stock tires over to the new rims. If they are a street tire and not an AT or MT you might get lucky and they may not rub. It’s the offset that causes them to rub. I have a two inch level lift with AT size tires and they clear my truck. I first bought 295 AT tires with my set up and they rubbed in reverse only at full tilt. My offset is different than yours so that’s why yours may work. It will be close. I would just be prepared to do a level in front.
1Roger
1Roger
Roger
So Cal
