turbopilot
Prescott, AZ
2023 F150 Powerboost
My 2021 PowerBoost with 7.2kw ProPower Onboard has a primary mission as a tow vehicle for a 25' Airstream Globetrotter trailer. Recently upgraded to Starlink In Motion High Performance phased array antenna and decided to put the antenna on the F-150 since ProPower Onboard is always available. Great performance with this setup using WiFi as WAN back to the Airstream. Be glad to post details of the custom install if anyone is interested.
Ford F-150 Starlink In Motion on a F-150 PowerBoost 🛰️ IMG_7184-L
More detail on the PowerBoost with Starlink In Motion phased array antenna.
In 2021 when I learned about the F-150 PowerBoost with 7.2kw ProPower Onboard it seemed like a perfect fit with a mid sized Airstream trailer. So I sold my Newmar Diesel Pusher and started what turned out to be a fascinating journey marrying the PowerBoost with an Airstream. After lots of calculations I decided a 25' Airstream Globetrotter was the best trailer for the PowerBoost. I ordered both in the Spring of 2021 and they booth arrived in the Fall of 2021. I quickly discovered the very heavy Platinum PowerBoost and 25' Airstream Globetrotter had some weight problems. The Airstream had a "heavy tongue" weight and the PowerBoost with every option only had 1,317 lb cargo capacity so something had to give.
The result was a total rebuild of the 2022 Airstream to remove around 200lbs of tongue weight by converting the trailer into an electric/diesel power trailer. All propane appliances were removed. That entire project is detailed and documented on the Airstream forum here. The Powerboost and the Airstream are connected in motion by an umbilical going to the Victron Inverter supporting four 100ah lithium batteries in the trailer.
I operated the PowerBoost and Airstream for a year with great results but the internet was never good with cellular modems. I decided to convert to Starlink just as the in motion antenna was released. Given that the PowerBoost had 7.2kw of power and Starlink can use up to 150 watts given my situation it made sense to mount the Starlink system on the F-150.
The first challenge is that there is a flaw in the high performance in motion Starlink connector. Starlink instructions say to mount the antenna connector forward into the wind on an 8 degree angle on the supplied aluminum mount. Early beta testers found out blowing a 70 mph breeze into that connection resulted in early corrosion. The solution is that I fabricated a custom mount laying flat on the sun roof with the connector well sealed and plugging in at the rear of the installation.
The custom mount uses 1" aluminum extrusion attached to four magnetic mounts. On the sun roof I used 3M VHB to adhere 4 thin sheet steel discs to the glass. So the magnetic mounts hold to the steel discs which in turn are held down by 3M VHB tape. The antenna only weighs 13 lbs. It is stable, secure and reasonably easy to remove.
Ford F-150 Starlink In Motion on a F-150 PowerBoost 🛰️ img_7169-x2-jpg
The Starlink power supply is located in the bed of the F-150. I am not using the Starlink WiFi router. Instead I substituted a Peplink MAX BR1 Pro 5G mobile router. This router has WiFi 6 which is very important in crowded campgrounds. The enclosure has a pair of USB fans.
Ford F-150 Starlink In Motion on a F-150 PowerBoost 🛰️ img_7196-xl-jpg
Ford F-150 Starlink In Motion on a F-150 PowerBoost 🛰️ img_7228-jpg
Ford F-150 Starlink In Motion on a F-150 PowerBoost 🛰️ img_7184-l-jpg-
The trailer is equipped with a Peplink MAX Transit Duo Pro cellular router. This router collects the output of the Starlink system via WiFi as WAN, then combines it with Verizon cellular to make a Speedfusion Cloud VPN connection. Speedfusion fuses the two WAN sources (Starlink and Verizon) to provide a stable signal.
There are other reasons to put Starlink on the tow vehicle. At time obstructions at a camp sight will degrade Starlink performance. If that happens I just move the truck to a better location with ProPower keeping Starlink alive and WiFi back to the trailer. When not towing the trailer I have full speed unlimited internet coverage anywhere the F-150 happens to be. My F-150 Propower On Board backs up the house now with power and full speed internet. The Powerboost will start and run a few minutes every 15 to 30 minutes powering the Starlink system.
One device that went away with this setup was the Dish TV satellite system. With the Starlink setup and unlimited internet, YouTube TV makes much more sense as a source of typical satellite TV services.
Very happy with the setup. I am on the new Starlink Roam service which is slower than the residential service but this is highly variable depending on location. So far I am seeing download speeds between 25 and 150 down with the Starlink Roam service. As more satellites launch the service continues to improve.
Aron
Aron
Civil Engineer
Cool!
I’m just curious—the onboard AT&T cellular connection wasn’t working well enough?
turbopilot
turbopilot
Prescott, AZ
Cool!
I normally roam the Western US off the interstate highways. Cellular data coverage is spotty and where available oversubscribed in the Summer months.
EricR
Eric
Boise, ID
Is the Starlink hardware providing your WiFi as WAN? If not, what gear are you using for this?
Also, a bill of materials with costs would be really nice!
turbopilot
turbopilot
Prescott, AZ
I will put together some images and links to the hardware I am using. This project started out very simple to provide Starlink to the Airstream, then the much better performing in motion antenna came out and changed many of my assumptions/use cases. As a result the project took on new dimensions.
discothan
SW Michigan
2021 F150 XLT
What are you using to fasten this down to your moon roof? I'd be afraid with the wrong gust of wind direction this antenna and other glass like material will be shattered.
Mash150
Dale
North of the 49th
21 King Ranch, 157, SQ , PB
Nice . What kind of speed to you get with your setup.
Ford F-150 Starlink In Motion on a F-150 PowerBoost 🛰️ 32141334-1F4B-422E-95B3-A3A0354862D7
turbopilot
turbopilot
Prescott, AZ
Ford F-150 Starlink In Motion on a F-150 PowerBoost 🛰️ IMG_7169-X2
Ford F-150 Starlink In Motion on a F-150 PowerBoost 🛰️ IMG_7196-XL
Ford F-150 Starlink In Motion on a F-150 PowerBoost 🛰️ IMG_7228
turbopilot
turbopilot
Prescott, AZ
As all Starlink users know it varies a lot depending on the local cell you are in. I have only had the system a month. So far I am seeing 25 to 100 down. The In Motion antenna with its 140 degree horizon is seeing 30 percent more sky than the older antennas. The result is that it is much more resistant to obstructions and is reported to be faster with a higher output phased array antenna.
I didn't snap that it was you (@turbopilot) when you first launched this thread.
I snatched your Birdseye view image and posted on another site about yet another clever use for Powerboost ProPower.
Then I saw your recent post about the Airstream and immediately put 2&2 together.
Nothing you do with a Powerboost and/or an Airstream would surprise me in the least! Not at this point, at least.
Hope you and yours have been enjoying that amazing rig. :)
turbopilot
turbopilot
Prescott, AZ
Thanks. The Powerboost and Airstream make a great combination. I guess that is why it is in all the Ford commercials. Here is the full rig before putting on the Starlink system.
Ford F-150 Starlink In Motion on a F-150 PowerBoost 🛰️ IMG_6215-X2
turbopilot
turbopilot
Prescott, AZ
Magnets and 3M VHB double sided tape. Based on my testing the magnets go before the VHB tape. Antenna is only 13 lbs.
discothan
SW Michigan
2021 F150 XLT
It will be a lot 'heavier' if you are traveling down the highway and the ensuing wind force gathers under the flat surface. Stick your arm out the window and flatten your hand parallel to the ground as you drive and feel the forces build under your hand.
wayfarer556
Austin, TX
2021 F150 XLT Powerboost 302A
You are living my dream, what a sublime project. Thank you for sharing.
