Stage Series Fog Pocket Kit for 2021+ Ford F-150 | Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Website
www.diodedynamics.com
2021 Ford F-150
Ford F-150 Stage Series Fog Pocket Kit for 2021+ Ford F-150 | Diode Dynamics RC2NWjM
Diode Dynamics is excited to introduce our Stage Series Fog Pocket Kit for 2021+ Ford F-150!
If you are looking to add some serious functionality to your F-150, look no further! The Stage Series Fog Pocket Kit for the 2021+ Ford F-150 from Diode Dynamics adds both road-legal fog lights and powerful offroad lighting. The CAD-designed brackets allow you to mount four SS3 LED Pods in place of your factory fog light housing. With the included harness, you'll be able to switch between road-legal fog lights and offroad lights with ease.
Ford F-150 Stage Series Fog Pocket Kit for 2021+ Ford F-150 | Diode Dynamics tb85jts
Focused: Most LED pods on the market, even certain premium options, use outdated technology like reflectors or simple lenses that lose light internally and to glare. By comparison, our custom-engineered total internal reflection (TIR) optic in the SS3 collects all of the light from the LED chips, drastically reducing wasted light and improving total efficiency.
Ford F-150 Stage Series Fog Pocket Kit for 2021+ Ford F-150 | Diode Dynamics YeR56xc
From there, while other options on the market lose as much as 10% of the light output shining through an outer lens, the custom-molded TIR optic in the SS3 serves as both the optic and main lens for greater efficiency and light output (patent pending). Thanks to this innovative feature, when coupled with high-intensity LED chips, the total intensity of the SS3 is much greater than other LED pods using basic optics or reflectors with a standard outer lens.
Lighting for Every Situation. This kit includes two SS3 LED pods in the SAE-compliant fog beam pattern and two SS3 LED pods in the combo beam pattern. This combination provides ideal light output whether you are on or offroad!
Ford F-150 Stage Series Fog Pocket Kit for 2021+ Ford F-150 | Diode Dynamics NG4EyB0
SAE Fog provides an extremely wide field of view, with high-intensity output over an entire 80-degree spread. It will fully illuminate the area in front of your vehicle.
Note: When installed as a pair and aimed in accordance with your state's regulations, the Fog pattern meets SAE J583 standard as a Foglamp, for legal on-road use. Please check your local laws and regulations for aiming, installation, and applicability.
Ford F-150 Stage Series Fog Pocket Kit for 2021+ Ford F-150 | Diode Dynamics zmVw0Da
Combo pattern combines both the Driving and Flood optics. It shines light downrange in a focused, rectangular 65x25 degree pattern. The combo lens features a flood optic on one side and a driving optic on the other.
Ford F-150 Stage Series Fog Pocket Kit for 2021+ Ford F-150 | Diode Dynamics bQUWoYy
White or Yellow Fog. The SS3 fog pods included with this kit are available in both cool white and selective yellow LED pod options. The white is a 6000K color temperature, which is a true cool white output, and matches most factory LED lighting. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a distinctive look on the road. The SS3 Combo offroad pods in both options are 6000K cool white.
Ford F-150 Stage Series Fog Pocket Kit for 2021+ Ford F-150 | Diode Dynamics N8JbAv5
Backlight Functionality. Each pod in this kit includes a distinctive Amber backlight feature that can be controlled separately using the factory aux switches. The backlight on each pod included with the kit fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products.
Sport, Pro, or Max. This kit is available at three different power levels. All options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. The Sport model uses high-intensity LEDs, and is the best bang for the buck you’ll find. The Pro model steps things up in a big way, with double the total power. Finally, the Max model features our SS3 Max LED pods, which have been designed with cutting-edge automotive emitters for both high power and extreme intensity. This brand new technology comes at a cost, but if you’re looking for the absolute best in lighting performance, the SS3 Max is the answer. Click the Specifications tab to see more information or click here to view our full specification guide.
Ford F-150 Stage Series Fog Pocket Kit for 2021+ Ford F-150 | Diode Dynamics Zy1JV59
Customizable: If you’re looking to change the output color, add a layer of protection, or simply add some extra style to your SS3 LED pods, our snap-on covers are a great option. Like our scratch-resistant SS3 lenses themselves, the SS3 Pod Covers are made with a strong polycarbonate plastic, to protect against whatever the road throws your way.
Independent Control. With the included harness and adapters, the two SS3 Fog pods and two SS3 offroad pods in this kit can be controlled independently, allowing you to switch between road-legal fog lights and offroad lights with ease. The included H10-size or Molex adapters connect the SS3 fog pods to your factory halogen or LED fog light connecter, while the off-road lights in this kit are controlled with either the included 3-way toggle switch, or a factory-installed aux switch.
Ford F-150 Stage Series Fog Pocket Kit for 2021+ Ford F-150 | Diode Dynamics WIpOi7I
Proven Reliability: Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
If you have any questions, please don't hesitate to post, PM, or email [email protected].
PM us for the free-shipping code (U.S. forum members only)
John C.
Diode Dynamics
Graygoose2021
Oklahoma
Sales
Very nice!!!
Wvmtneer
Usa
@Diode Dynamics i’m sure this is premature, but do you plan on having an elite series fog light kit instead of the ss3 pods? The factory LED fog running lights would be killer with SAE DD amber fogs.
SpaceWhiteF150
Montgomery, Texas
Same, wish y’all came out with something that looked more oem+. Like the Superduty SS3 kits, the subtle look with killer output!
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Website
2021 Ford F-150
Thank you both for the feedback!
We're always looking to offer more products for the 14th generation F-150.
We'll be sure to post updates on any new or future products for the 2021+ F-150. Stay tuned!
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Website
2021 Ford F-150
Ford F-150 Stage Series Fog Pocket Kit for 2021+ Ford F-150 | Diode Dynamics 6eYlRNz
Our Labor Day Sale starts NOW! Today through Friday, 9/9/2022, save 15% on all LED upgrades by entering coupon code "LABOR22" at checkout!
Plus, all orders over $300 will receive free US shipping.
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 9/9/2022. Cannot be combined with other coupon codes.
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Website
2021 Ford F-150
Ford F-150 Stage Series Fog Pocket Kit for 2021+ Ford F-150 | Diode Dynamics TbYfg9J
The clock is ticking!
Hurry! There are ONLY 3 DAYS LEFT to save on your favorite LED lighting products from Diode Dynamics.
Click HERE to shop!
John C.
Diode Dynamics
Graygoose2021
Oklahoma
Sales
$560 for the Sport is a good price!
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Website
2021 Ford F-150
Ford F-150 Stage Series Fog Pocket Kit for 2021+ Ford F-150 | Diode Dynamics 8VPwHNR
ALERT: LAST CHANCE TO SAVE!!!
Until 11:59 p.m. CST on 9/9/2022, you can use coupon code "LABOR22" at checkout for 15% off your entire order of lighting upgrades.
Plus, all orders over $300 will receive free US shipping!
Don’t wait, this sale ends TONIGHT!
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 9/9/2021. Cannot be combined with other coupon codes.
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Website
2021 Ford F-150
⌛THE CLOCK IS TICKING... ⌛
NOW
is your chance to SAVE up to 15% sitewide on your favorite Diode Dynamics LED lighting products.
➡ Up to 15% OFF LED Lighting Upgrades
➡ 15% OFF Stage Series Rock Lights & HitchMount LED Pods
➡ 10% OFF Elite Series JL/JT Headlights
➡ Free US Shipping on any order over $300!
CLICK HERE TO SHOP NOW
Ford F-150 Stage Series Fog Pocket Kit for 2021+ Ford F-150 | Diode Dynamics qD4beIR
Did you know?
You can find all of the products we offer for your vehicle using our vehicle finder tool! Simply enter the year, make, and model.
SALE EXPIRES 11:59 P.M. MONDAY, MARCH 13TH, 2023.
Discounts cannot be combined with other offers or any previous orders. Excludes items with pre-order status.
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Website
2021 Ford F-150
? Our Memorial Day Sale is LIVE!!! ?​
➡ Up to 15% OFF Sitewide
➡ 10% OFF JL/JT Elite Series Headlights
➡ Free US Shipping on any orders over $300!
Excluded: F150 Elite Series Headlights, and F150 Elite Series Fog Lights
John C.
Diode Dynamics
Hours: Monday-Friday 10 a.m. - 5 p.m.
Email: [email protected]
Phone: 314-205-3033
Sale ends 11:59 p.m. CST on Friday, 6/2/2023. Cannot be combined with other coupon codes.
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Website
2021 Ford F-150
⏳ LAST CHANCE! TODAY IS THE LAST DAY TO SAVE! ⏳
➡ Up to 15% OFF All Lighting Upgrades
➡ FREE US Shipping on any order over $300!
No coupon code is required.
Click HERE to shop lighting upgrades for your ride!
? Sale ends 11:59 p.m. CST on Friday, 06/02/2023. Cannot be combined with other coupon code ?
John C.
Diode Dynamics
Phone: 314-205-3033
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Website
2021 Ford F-150
Ignite your lighting game this July 4th!
➡ 20% OFF Single Row Stage Series Light Bars
➡ 15% OFF Sitewide
➡ 10% JL/JT Elite Series Headlights
Plus, score FREE shipping and a FREE Diode Flag Tee with any purchase over $300!
NO COUPON CODE REQUIRED
https://www.diodedynamics.com/ ⬅
Expires at 11:59 p.m., Friday, July, 7th, 2023.
