Sport mode 4x4 on dry pavement?
20acrefarms
Scott
Enniskillen Ontario Canada
2019 VW Atlas, 2023 F150 XL
Industrial Fire Fighter
I was always under the impression that you shouldn’t use 4x4 on dry pavement. In sport mode it engages 4x4. Can someone smarter than me explain why this is now ok.
Oxford_Powerboost
Austin
Northern Virginia
2023 F150 Lariat 5.0
it’s engaging 4 Auto. 4 auto is not the same as traditional 4wd that you’re thinking of (4Hi). 4 Auto is supplying power to all 4 wheels but the center differential (transfer case) is unlocked, which means the front and rear axles can spin at different speeds, which alleviates the issue of using it on pavement. It’s basically AWD in 4 Auto, and 4 Hi is traditional 4WD that will bind up on hard surfaces. 4Auto is great for putting power down (hence why it does it in sport mode) and for times like when it has snowed and snow plows have been out but there are still some slick spots.
20acrefarms
20acrefarms
Scott
That is interesting. I have a XLT that doesn’t have the auto button for 4x4.
RayRay
Ray
Springwater, On, Canada
2021 XLT SPORT SCAB 302A 2.7
Tosh
Willamette Valley, Oregon
2021 F150 Lariat Powerboost, 2024 Mach E Rally
Re-Tired Bicycle Mechanic
You're right about not using 4Hi on pavement - that's also in the manual.
I suspect that Sport mode for a truck w/o 4A is actually 2Hi rather than 4Hi. Sport mode in my Lariat defaults to 4A, but I can then select 2Hi, and it's still in Sport mode.
20acrefarms
20acrefarms
Scott
well sorry for wasting everyone’s time. I went out this morning and double checked and it did not go into 4x4. I think when I was cycling through modes and it went into off road mode then Switched to sport and saw “4x4 shift in progress” I assumed it was going into 4x4 not out of 4x4. Sorry fellas
KartRacer25
Richard
San Diego
Yeh. Ive done a few 0-60 tests in sport mode then have to hit 4H manually. Again only in a straight line then switch back to 2H. Yeh I tried some of the other modes that switch in out of 4H to 2H automatically. I don't have rock crawl but thinking of adding it via Forescan. I think thats the only one that goes into 4L automatically. Maybe hill decent too. Pretty versatile. I also found off road display mode, nice, with pitch, roll and steering angles. kool
SRHAGEN
S
RICHMOND ky
2016 F150 XL SPRCAB Sport 4x4 V8 3.73 36 gl tank.
DOD USAF test track ARMY RETIRED PMEL/TMDE
Where is the sport mode select. Can’t find it on my 22 XLT SC 4x4 sport 5.0. I can’t find tow mode either.
Kidder
DFW, TX
2025 F250 Lariat PS HO
Do you have dial that is in the middle of the 2 and 4wd modes? Rotate that left or right for different drive modes.
In this pic, to the left of the climate controls:
Ford F-150 Sport mode 4x4 on dry pavement? w_XLT_4x4_PowerB_cockpit_nav_P2000614_bc-2048x1537
SRHAGEN
S
RICHMOND ky
Thanks for the reply. I found it playin around today. Thought it was in the gage setting somewhere. Doh. It’s all there. Could not find it in the manual anywhere lots to read about this machine.
