Administrator
Administrator
Staff member
F150GEN14
Admin
Next 2021 Ford F-150 May Be Even Larger Than the Current Truck (Spied)
Ford F-150 Spied: 14th Gen Ford F-150 Appears To Be Larger Than Current Model 2021-ford-f150-prototype-old-versus-new
Check out this 2021 Ford F-150 prototype parked next to a current F-150 truck? Does the new prototype appear to be larger in nearly every dimension, or is this simply an optical illusion?
The images you see here are courtesy of Will V.
2021 Ford F-150
New trucks keep getting larger in size, but how much bigger can they get? Ford is clearly working on the next version of the its most popular vehicle – the F-150. Will they re-use the existing aluminum cab and bed, or will they update certain body parts and components to make it more cavernous, usable, or improved? The actual answer is somewhere in the middle.
Most spy images of the 2021 prototype show an extended and crew cabs that appear to be largely carry-over from the current F-150. The wheelbase and/or bed may become a bit larger to provide more utility.
Here is our TFLtruck prototype hunting video that shows an F-150 extended cab test truck.
The new F-150 may also become taller to offer more ground clearance and off-road capability. There is an unconfirmed rumor that the next F-150 will get one or two additional off-road packages, in addition to the FX4. Perhaps, a 2021 F-150 Tremor off-road truck?
Naturally, we also expect the 2021 truck to have updated mechanicals. It’s not secret that Ford is planning a gas/electric hybrid F-150. An all-electric F-150 is also in the works, but that will come later.
Here is another prototype video showing a 2021 F-150 prototype towing a sizable trailer in the mountains.
Degrominator
Garden City, NY
F-150 King Ranch
Love how imposing the larger front grille looks. Can't tell details of it yet but it looks taller and wider than the current F-150 front.
Fiver-O
Central Ohio
Explorer
It's almost as if they adopted the front clip of the current Raptor. Should be very imposing. Can you imagine what the next gen Raptor will look like <drool>
BOB L
Bob
OKC
2013 Mustang GT, 2015 Wrangler
Hope it's just the perspective making it look bigger. The F-150 doesn't need much changes and needs to stay dimensionally the same. GM went and screwed up the Silverado and Sierra redesign by making them too big (too tall and wide). It negated MPG gains from the better powertrains and lower weight. The F-150 is more than capable against the RAM and Silverado without growing in size.
Mando
Kirk
FL
2010 Ford F-150 XLT
I dont think it's grown in size, that is probably just the heavy cladding making it look that way. I wouldn't mind if they sharpened up the exterior, give it a more chiseled look but keep it same size.
