Side vent lighting
Pipelineguy
Wayne
Alberta
2021 f150
Inspector
looking to install side vent lighting on my 2021 f150. Tried to follow f150led instructions but truck has the quad led lights. Their video says nothing about how to connect to it. They make it look so simple. No thanks to them I’m hearing I can unplug headlight plug and feed up to above light area to connect. Does anyone have any knowledge of this. Please.
mrbuntman
Rudy
Centerton, AR
Business Analysist
Following was about to swap vents and put the lights in.
ERM
Eric
Salt Lake City
2021-Tremor
Technical Security
I ordered LED reverse lights from these guys that were supposed to be a perfect fit for a 2021 Tremor. "Easy 5 minute install". I removed one back light assembly only to discover they were sealed units... They took the return with no issue though. If you look at the warning notes (small print) many of these upgrades run VERY hot, like hot enough to fry anything that comes close to them after install. Hard pass.
Sparkybrent
Brent
Utah
2021 F-150 Lariat LB
Electrical Contractor
I installed them on my 21 Lariat. You have to use the side marker wiring which is really short. I did it above the fender skirt, but it was a difficult install. Couldn't figure out how to remove the headlight without getting into the grill, etc. I really like mine and in the end it was worth it. They have been on now for about 20 months.
