Reverse lights- LED upgrade?
gooby
FL
2022 F150 XL
Have a '22 XL with halogens. I would not mind more backup camera visibility at night. I don't want to blind drivers so I don't plan on upgrading my halogen tail-lights to LED bulbs, however, I am considering upgrading just my backup lights to LED's. I figure if I am backing up, I don't need to worry about light output being excessive. Has anyone upgrades to these or equivalent? Thanks
https://www.diodedynamics.com/backup-leds-for-2015-2023-ford-f-150-pair.html
Eskram
Fl
2022 F150 Lariat PB 502a
I used these - AUXITO 194 LED Bulbs 168 175 2825 W5W T10 24-SMD 3014 Chipsets 6000K White for Car Dome Map Door Dash Instrument Courtesy License Plate Lights Pack of 2 https://a.co/d/ewK2aen
They match the OEM colorand seem to be pretty bright.
Eskram
Fl
I can't read... Reverse lights, not tag lights..
Carry on. I got nothing there.
SpaceWhiteF150
Montgomery, Texas
I replaced with lasfit led bulbs, great value and they haven’t burned out yet!
Also added DD SSC2 pods, here’s some output shots with lasfit led bulbs and DD pods! Perfect setup.
Ford F-150 Reverse lights- LED upgrade? E86D3B90-6302-4A2C-838E-AA46C8EFD707
Ford F-150 Reverse lights- LED upgrade? D235A486-2261-4DBD-85BF-B54E3578FFA1
Ford F-150 Reverse lights- LED upgrade? 5E0F1D43-794A-4105-8469-FAF8B627545C
Ford F-150 Reverse lights- LED upgrade? E16B5ADE-EF78-44AE-8D32-EFF29F387E36
Ford F-150 Reverse lights- LED upgrade? 32C8BBA3-5C50-4973-BFE5-38BE67E823CC
gooby
FL
2022 F150 XL
Nice! Did you do the third brake light in LED's as well? No issues there either? I don't really see the downside since these are really only going to make it safer for backing up, right? Like I understand the argument of not using LED's in halogen housings because they blind other drivers.
SpaceWhiteF150
Montgomery, Texas
I think that only holds true for forward facing lights, even then if they are aimed right they do great. I know crazy opinion compared to popular belief! Especially on the rear, the 360 degree light dispersion on the bulbs just brightens and makes it easier for others to see you! I replaced every rear facing bulb with lasfit leds. Turn signal, brake light, reverse light, cargo, plate lights!
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
Website
www.4x4TruckLEDs.com
2018 Raptor & 2021 Bronco Outer Banks
Drug Dealer of the LED World
If you want some of the brightest LED bulbs available, check out our CrystaLux Xtreme Series. You'll just need to know if you have the 3157 or 7443 bulbs (as Ford decided to use different bulbs for different trucks/trims, go figure!)
https://www.4x4truckleds.com/crystalux-xtreme-series-2-920-lumen-led-reverse-bulbs-pair/
Here's a shot on a Gen1 Raptor for example. These are NOT his headlights, these are his reverse bulbs
Ford F-150 Reverse lights- LED upgrade? 1675034224040
Ford F-150 Reverse lights- LED upgrade? 1675034228018
Another option, if you have a trailer hookup, is our new Diode Dynamics Reverse Kit. It's a plug and play kit that installs in a few minutes. It uses an in-line connection to the trailer connection (behind the bumper) while NOT losing function of the trailer OR generating error codes
https://www.4x4truckleds.com/dual-l...-diode-dynamics-lights-7-pin-trailer-harness/
Ford F-150 Reverse lights- LED upgrade? 1675034271006
Graygoose2021
Oklahoma
Sales
I did F150leds.com in reverse and 3rd brake light. Huge upgrade
AUXITO Jackson
Upland, CA 91786
Website
www.auxito.com
2021 F-150
Senior Manager Of The Official AUXITO Brand Website
我使用了这些 - AUXITO 194 LED 灯泡 168 175 2825 W5W T10 24-SMD 3014 芯片组 6000K 白色,适用于汽车圆顶地图门仪表板礼貌车牌灯 2 件套https://a.co/d/ewK2aen
它们与 OEM 颜色相匹配,看起来非常明亮。
[/引用]
Thank you very much for your love of AUXITO bulbs, if you are interested in other AUXITO bulbs please let me know and we will be happy to send them to you for a performance review!
AUXITO Jackson
Upland, CA 91786
Website
www.auxito.com
2021 F-150
I got AUXITO LED bulbs to upgrade my reverse lights. Plug and play. Easy to install. Much brighter than halogen bulb. I can finally see where I'm going when backing into a space even though I have tinted windows at 35% all the way around the car.
https://www.auxito.com/pages/parts-and-accessories-for-ford-f150
I'm sure you'll be impressed with our brake lights as well, would you be interested in a performance review of them?
https://www.auxito.com/collections/...rn-signal-light-bulbs-for-2004-2022-ford-f150
