WhiteLightningnshitshadow
I've had this slight driveline vibration between 50-60mph for a little while now after removing the flat rear blocks and tried a few things. I did confirm problem is much reduced with blocks in, but the pinion angle is the same! I don't have an inclinometer, but the angles seem to match.
I figured on trying 1 degree belltech shims, so I spent all day today trying them both ways. I still had vibration with the shims. I'm about to give up with this thing and take it to a driveline shop.
I would almost consider putting the blocks back in, but more than ugly rake, it doesn't handle or brake nearly as well. Plus the bed height is way too high.
Anyone else run into this?
