Looking for 2025 Key Fob part number
hamd1786
Syed
Arlington, TX
22 Tacoma SR, 22 F-150 Lariat
As the title says I am looking for the part number to order the key fob. Lost it over the weekend.
the only thing I have on my second key fob is RL3T-15K601-BA1 it’s for push button start key fob
the parts website doesn’t really pull up anything
so I figured someone here can help me guide in the right direction
JohnTrigger
MD
‘24 F-150 STX 2.7L SCREW
I suspect it is this one, does it look like this? Looks are one thing. Try to find more numbers, especially the FCCID number (use magnifying glass, and pull out emergency key to look too) on your remaining fob-that number must match. The one below is FCCID:M3N-A3C108397
https://www.keylessentryremotefob.com/ford-f-250-oem-5-button-key-fob-w-remote-start-m3n-a3c108397/
With only one you can’t program it yourself unless you use FDRS (and I’m no longer sure you can do that either since it now may require a login to the BCM module). You'll have to use dealer or pro locksmith. If you still had two, it’s simple to do yourself:
https://www.fordservicecontent.com/...A&div=f&vFilteringEnabled=False&buildtype=web
You’ll have to get the emergency key cut too. You probably had a small card with a number on it in glovebox when you bought truck that tells them the code used to cut it; or they can look it up at your dealer with proof of your ID for a fee. They can also do it the old fashion way with a second key to trace. Your Ford Dealer will likely only deal with an OEM key fob for the key cut and programming. The one above is OEM it’s just remanufactured. I’ve bought from them myself.
