Largest Tire on Leveled Limited?
DBJohnston0104
United States
2016 F150 Limited / 2021 F150 Limited
I'm wanting to put some bigger Ridge Grapplers on my truck when I get it but can't seem to find an answer to this. Can a 295/55/22 fit on a leveled Limited without issues? I see a good bit of info on a 295/65/20 but can't anything about the 22". I really want a 35/12.5/22 on it which is what I currently have on my 2016 Limited but from what I'm seeing it won't fit. Looks like the width is an issue.
TAZEVEDO317
Tiago
Holtsville NY
20 F-150 Lariat - 22 F-150 Platinum on order
Sayville Ford Sales Manager
Replying because I'm looking for the same response.
Someone has to have fit something similar.
Maybe even a 2.5" level with a 3/4" rear level.
vinhdiesel
vin
bay area
2021 f150 platinum
i believe if you want 35" tires, you would need a minimal of 2.5 inches raised if you dont want any rubbing
i have bilstiens 6112 and its raised about 2.25 with 295 60 20 +15 offset, so its about a 34" tire and it barely clears it.
your off set is going to be your main factor to the rub
DBJohnston0104
DBJohnston0104
United States
So I found out that you can fit a 295/55r22 by only leveling it. While not technically a 35" it's pretty close at 34.8" which, to my knowledge, is the largest you can fit with just a leveling kit.
DBJohnston0104
DBJohnston0104
United States
Mjackson704
Matt
Nc
2022 F150
I currently have raptor take offs which are 315/70r17. I believe the wheels have +34mm offset. Two inch level and no rubbing.
Waveslider
2021 F-150 SCREW Lariat 4WD
What brand of tire are your 34’s that barely clear? Most people are saying they clear 34’s no problem with a +18 offset. I can’t imagine the extra +3 offset makes that much difference? I just did Fox coils and got about 2” of lift and need to make a decision on tires. I’m going back and forth between 295/60r20 and 285/60r20.
vinhdiesel
vin
bay area
2021 f150 platinum
29560r20
Nitro ridge grapplers
