Is Ford complying with their own storage procedures?
busdriver
C
Tyrone
2010 F150
Pilot
The Ford owner's manual lists procedures for storing a vehicle for over 30 days. My truck has been in storage so far for 90 days. It'll probably be well over 120 days by the time it gets the chips. What are the chances that Ford is complying with their own procedures for vehicle storage? I'm thinking of cancelling my order and maybe try again for a 2022 or even a 2022 Tundra.
PREPARING YOUR VEHICLE
FOR STORAGE
If you plan on storing your vehicle for 30 days or more, the following maintenance recommendations ensures our vehicle stays in good operating condition. Under various conditions, long-term storage may lead to degraded engine performance or failure unless you use specific precautions to preserve your vehicle.
General
• Store all vehicles in a dry, ventilated place.
• If vehicles are stored outside, they require regular maintenance to protect against rust and weather damage.
• Make sure all linkages, cables, levers and pins under your vehicle are covered with grease to prevent rust.
Move vehicles at least 25 ft (7.5 m) every 15 days to lubricate working parts and prevent corrosion.
Fill the fuel tank with high-quality fuel until the first automatic shutoff of the fuel pump nozzle.
Engine
• Change the engine oil and filter prior to storage because used engine oil contains contaminants which may cause engine damage.
Start the engine every 15 days for a minimum of 15 minutes. Run at fast idle with the climate controls set to defrost until the engine reaches normal operating temperature.
• With your foot on the brake, shift through all the gears while the engine is running.
Body
• Wash your vehicle thoroughly to remove dirt, grease, oil, tar or mud from exterior surfaces, rear-wheel housings and the underside of front fenders.
• Periodically wash your vehicle if it is stored in exposed locations.
• Touch-up exposed or primed metal to prevent rust.
• Cover chrome and stainless steel parts with a thick coat of auto wax to prevent discoloration. Re-wax as necessary when you wash your vehicle.
• Lubricate all hood, door and luggage compartment hinges and latches with a light grade oil.
• Cover interior trim to prevent fading.
• Keep all rubber parts free from oil and solvents.
Hybrid Battery Systems
We recommend the following actions foryour vehicle:
When storing your vehicle for greater than 30 days the state of charge should be approximately 50%.
Additionally we recommend disconnecting the 12V battery which will reduce system loads on the HV battery.
12 Volt Battery
• Check and recharge as necessary. Keep connections clean.
Note: It is necessary to reset memory features if you disconnect the battery cables.
Brakes
Make sure the brakes and parking brake release fully.
492
dweller
Jonathan
Maryland, USA
Soon maybe 2021 F-150 Lariat 3.5EB 4x4 Lead Foot
Army
The logistics alone required to do this for 10s of thousands of vehicles makes it seem very unlikely. If the routine maintenance took exactly 10 minutes, it’d take over 400 calendar days to complete. That’s working 24 hours a day and exactly 10 minutes for each vehicle. To get it down to 15 days so you’d finish the last car as the first one was coming up on its next maintenance, you’d need over 80 people working constantly for only 10 minutes of each vehicle.
hopefully I’m wrong though.
